INSTALLED SKUNK2 MANI ON B18C - starts then dies please HELP!!! (video)
ALRIGHT GUYS, IVE SEARCHED EVERY FORUM ( FROM RESENT TO ARCHIVED STILL NO LUCK)
I JUST SWAPPED THE NEW B18C MOTOR IN MY CAR A FEW DAYS AGO,(THANKS HMOTORS!)
... ANYWAYS IT BEEN DRIVIN FINE TILL TODAY...
I DECIDED TO INSTALL MY NEW SKUNK2 MANIFOLD... EVERYTHING WENT IN JUST FINE, HAVE BEEN DOING SOME RESEARCH JUST TO MAKE SURE I DO THE INSTALL RIGHT.... ALL PLUGS ARE PLUGGED IN, NEW GASKETS WERE INSTALLED, COOLANT REFILLED, AND EVERYTHING WAS BACK ON TIGHT...
NOW... HERES THE PROBLEM....... WHEN I START THE VEHICLE UP IT STARTS AND IDLES @ AROUND 1500-3000 RPM THEN AFTER IT WARMS UP IT'LL SLOWLY IDLE DOWN THEN DIE
HERES SOME PICS OF THE FINISHED INSTALL.....SCROLL DOWN FOR THE LINK OF THE VIDEO..(I'M PRETTY SURE I PLUGGED EVERYTHING ELSE BACK IN THE RIGHT SPOT. IF NOT, TRY TO SEE WHERE I WENT WRONG ..) THANKS GUYS!!!! :
HERES ALSO A LINK TO A VIDEO OF THE MOTOR DOING WHAT I JUST EXPLAINED:
SHOT OF THE MOTOR:
SHOT OF THE GAUGE:
... ANYWAYS IT BEEN DRIVIN FINE TILL TODAY...I DECIDED TO INSTALL MY NEW SKUNK2 MANIFOLD... EVERYTHING WENT IN JUST FINE, HAVE BEEN DOING SOME RESEARCH JUST TO MAKE SURE I DO THE INSTALL RIGHT.... ALL PLUGS ARE PLUGGED IN, NEW GASKETS WERE INSTALLED, COOLANT REFILLED, AND EVERYTHING WAS BACK ON TIGHT...
......HERES SOME PICS OF THE FINISHED INSTALL.....SCROLL DOWN FOR THE LINK OF THE VIDEO..(I'M PRETTY SURE I PLUGGED EVERYTHING ELSE BACK IN THE RIGHT SPOT. IF NOT, TRY TO SEE WHERE I WENT WRONG ..) THANKS GUYS!!!! :
SHOT OF THE MOTOR:
well first of all it sound as the motor did not want to start right away. 2nd sounds like it's sucking way more air than needed. then once the motor starts to get warm the idle drops way down... try up the idle screw to the max...
I noticed that your gas tank is empty. Have you tried putting gas in it and giving it gas to get fuel back to all of the lines that you disconnected?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d »</TD></TR><TR><TD CLASS="quote">well first of all it sound as the motor did not want to start right away. 2nd sounds like it's sucking way more air than needed. then once the motor starts to get warm the idle drops way down... try up the idle screw to the max...
I MAXED THE IDLE SCREW UP AND DOWN STILL SAME RESULT...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmturbo1127 »</TD></TR><TR><TD CLASS="quote">I noticed that your gas tank is empty. Have you tried putting gas in it and giving it gas to get fuel back to all of the lines that you disconnected?</TD></TR></TABLE>
I THOUGHT THAT , THAT WAS THE CASE ALSO BUT I HAD STARTED IT A COUPLE OF TIMES BEFORE WITH ENOUGH GAS (just above E LINE) STLL THE SAME RESPONSE..... BUT IMMA TRY TO MORE GAS IN IT 2NITE...I HOPE THATS SOLVES IT BUT IF NOT THEN.......HELP!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nello a. »</TD></TR><TR><TD CLASS="quote">any cels</TD></TR></TABLE>
NOPE
NO CHECK ENGINE LIGHT....
NOPE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Lobster »</TD></TR><TR><TD CLASS="quote">sounds liek gas to me.
and what is with teh caps?</TD></TR></TABLE>
CAPS???
CAPS???
Yea i had a customer car that wouldnt idle worth a day in its life. Itll start but thats it. Then i looked down at the gas gauge and sure enough it was empty. Made him come over and put gas in and never had that problem again.
Even if it might not be the same problem you shouldnt have this little of gas in there.
First of all I wanted to say thank you to everyone for replying to my problem. Just goes to show you that in the heat of the moment you forget to look at the little things, and I'm not the only one that's guilty of it!!!
YES!
It was the gas.......
YES!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92CiVicSI79 »</TD></TR><TR><TD CLASS="quote">First of all I wanted to say thank you to everyone for replying to my problem. Just goes to show you that in the heat of the moment you forget to look at the little things, and I'm not the only one that's guilty of it!!!
YES!
It was the gas.......</TD></TR></TABLE>
That is a good one
Everybody has those moments!!! he he still laughing!!
YES!
It was the gas.......</TD></TR></TABLE>That is a good one
Everybody has those moments!!! he he still laughing!!Honda-Tech Member
haha, i bet you feel relieved that something isnt f*cked up with your new b18c or new skunk2 mani
how much did you pay from hmotors if you dont mind me asking?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard »</TD></TR><TR><TD CLASS="quote">haha, i bet you feel relieved that something isnt f*cked up with your new b18c or new skunk2 mani
how much did you pay from hmotors if you dont mind me asking?</TD></TR></TABLE>
For the B18c complete w/ LSD shipped to my work at $3,995.00...
a lil too much but i defenitely needed it cuz my d16 was starting to f#$k up.....
a lil too much but i defenitely needed it cuz my d16 was starting to f#$k up.....</TD></TR></TABLE>
dude you could have bought a itr motor for 3,999.00!!
