ecu code 14---help!
just dropped in a jdm gsr into my 94 integra...started up...has code 14, iacv has been replaced also tps, and adjusted accordingly, ecu was reset, same code, ecus switched, same code..also when warms up loses power...only code found is 14...ne suggestions?
if you are having all those problems and not one of those solutions helped then may be you should look at the wiring to the ecu or the wiring to the iacv because if you changed your ecu and changed the iacv and still have problems then i think your wires could be messed up. i had a simular problem where i had a code 14 and every thing i did didnt work but when i completely switched the ecu it fixed my problem
T--Rex
Jul 10, 2004 02:15 PM
