Anyone here ever shaved the brake caliper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UCI_Type-R »</TD></TR><TR><TD CLASS="quote">i say maybe like a 1/4 of an inch. off the corner where it curves to the front .</TD></TR></TABLE>
Why not use a 5mm wheel spacer?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike »</TD></TR><TR><TD CLASS="quote">
Why not use a 5mm wheel spacer?</TD></TR></TABLE>
x2
x2
the thing is that if i were to use spacers i would need to extend the lugs and if i do that the wheel will hit the fender due to the reason that the car is dropped.
I shaved my calipers in order to make rims fit about a yr ago. The correct sized spacers weren't available so I just shaved material off. I took off around 1/8-3/16 of material and have had zero problems with them. Only thing I noticed was that the metal developed the surface cancer after the first rain so I just sprayed both calipers with high temp black paint.
Like I said ... I've had zero issues. No cracking ... no nothing.
Hope this helps.
Hope this helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UCI_Type-R »</TD></TR><TR><TD CLASS="quote">the thing is that if i were to use spacers i would need to extend the lugs and if i do that the wheel will hit the fender due to the reason that the car is dropped.</TD></TR></TABLE>
You can run a 5mm spacer without having to extend the lugs.
We shaved 2mm of the mounting point of a prelude caliper to fit it on a civic race car, works fine, only other option is to run spacers between the hub and rotor
proudcss
Honda Civic (2001 - 2005)
Dec 27, 2007 07:42 AM
Drinker
