Brake Pads which side
alright my brand new ebc brake pads just came in. i opened the box up to check them out and i think they messed up
the long metal part sticking up is only on one of them? WTF does it even matter if so which side should i put it on?
The metal tab is the indicator for when the pads get low. You should have gotten two pads with tabs. When installing the pads with the tabs in the piston side of the caliper and the tab on the leading edge of the rotor because the leading egde wears faster then the following edge.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jacobolito »</TD></TR><TR><TD CLASS="quote">okay sounds good put which other one should i put piston side?
The tabs go on the piston side. They would stick out and interfere with the wheel otherwise.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jacobolito »</TD></TR><TR><TD CLASS="quote">i know that put look at the pads only one has a tab! that was the question
As mentioned before, the set is defective.
arent the tabs to see if they need replacing? and if i put them on anyway will it make a diffrence? i just dont want to send them back and wait for a refund
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Geeezer »</TD></TR><TR><TD CLASS="quote">Dude use some periods or something. I can't tell when your sentences end or begins.</TD></TR></TABLE>
sorry geezer. im just typing fast.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jacobolito »</TD></TR><TR><TD CLASS="quote">are you sure? i just dont want to mess anything up. </TD></TR></TABLE>
What everyone is saying is that the tab is just a sensor for when the brakes get low. Makes that cool squeeking sound that everyone loves. But it <U>does not</U> affect the performance of the pads. You will stop fine with or without that sensor.
It's just that without the tab, you'll have to monitor the condition of your brakes alittle more closely...which you should be doing anyways if you do any form of racing or spirited driving.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CARMA_626 »</TD></TR><TR><TD CLASS="quote">
It's just that without the tab, you'll have to monitor the condition of your brakes alittle more closely...which you should be doing anyways if you do any form of racing or spirited driving. </TD></TR></TABLE>
cool thanks just what i wanted to hear. ill proceed with the brake work thanks for all your help guys.
