*****GF car has bad upper ball joint...I think*****
Old Mar 23, 2007 | 08:13 AM
headrec*'s Avatar
Default *****GF car has bad upper ball joint...I think*****
Hey
Well here's the issue. My girlfriend got an alignment on her accord and noticed a knocking noise after the alignment. I did her brake pads and notice that I could move the ball joint by grabbing the assembly here in the middle (I would call it the steering knuckle?) and moving it back and forth.
Now normally I would believe it to be bad but took back to the alignment shop because the steering wheel was off center and they said she had bad wheel bearings this time around??? The weird thing is that there is nothing that makes me think they are bad.
Bottom line if i grab the knuckle and shift it around and ball joint has play and makes the noise she is describing would that be the problem even though the shop said otherwise? Also are the joints messed with at all during camber adjustment? I just need some backup on this guys. Thanks!
Old Mar 23, 2007 | 09:07 AM
winmac's Avatar
Default Re: *****GF car has bad upper ball joint...I think***** (headrec*)
a small amount of play is acceptable in balljoints, my rule of thumb is less than 1/16 of an inch is ok.
You would not need to seperate the joints to adjust camber, Inorder to change the wheel bearing you would have to seperate them.
Old Mar 23, 2007 | 12:17 PM
headrec*'s Avatar
Default Re: *****GF car has bad upper ball joint...I think***** (winmac)
It's more then a 1/16th. I'd say like 1/4-1/2 (kind of broad measurement but you know). Its more then noticeable and then the fact you can hear it when you move it makes me think so. Plus the other side is stiff as hell.
avio07
Jun 21, 2012 03:25 PM
thanh4o8
Jul 23, 2008 09:50 PM
EG_93Civic
13
Feb 8, 2006 08:01 PM
tolowhb
Apr 2, 2002 05:26 PM
95gsr
Jan 11, 2002 12:35 PM
