what is shift solenoid?
Old Mar 23, 2007 | 05:47 AM
xkrntamax's Avatar
Default what is shift solenoid?
i got engine code from advance auto and they told me i need to change solenoid
but i dont know what is solenoid.
can anyone tell me what is solenoid and where can i get fix from?
P0700
Trans control sys
Malfunction
P0700
Trans control sys
Malfunction
P1753
Manfacurer contrl
transmission
P0758
Shift Solenoid B
Circuit Electrical
P1794
Manfacurer Contrl
Trnas.
Old Mar 23, 2007 | 07:30 AM
Danziver's Avatar
Default Re: what is shift solenoid? (xkrntamax)
Im not sure, but looking my freinds car the other day i saw he had 2 solenoids (or maybe it was one) on the front of his automatic tranny casing. They looked just like the vtec solenoid.
Old Mar 23, 2007 | 09:41 AM
xkrntamax's Avatar
Default Re: what is shift solenoid? (Danziver)
what happen if i dont change the shift solenoid?
Old Mar 23, 2007 | 06:06 PM
rocklobsta's Avatar
i think the shift solenoids control the flow of tranny fluid in valve body to activate clutches and bands in the tranny. i believe that if they go out, the tranny is stuck in 2nd or 3rd and will not shift, kinda like a limp home mode. some one else please chime in if im wrong. are you driving the car now?
Old Mar 23, 2007 | 06:46 PM
xkrntamax's Avatar
Default Re: what is shift solenoid? (rocklobsta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocklobsta &raquo;</TD></TR><TR><TD CLASS="quote"> are you driving the car now?</TD></TR></TABLE>
actually no...
just put it in my garage...
bc in the morning time i crank up the car..it works fine
but after i drive awhile and stop and try to crank up my car, it wont crank up.
so i change spark plug, main relay, distributor, fuel pump, but still it wont crank up
after i drove a while.
thats y i went to advance auto to check the engine light, and they give me that code which is not relate to starting problem.
but im not driving the car.
Old Jan 8, 2017 | 02:37 PM
lexon77's Avatar
Default Need help
Hey guys I have a question I just gote a 98 Integra automatic transmission when I turn the car on and start to drive when it shift gears it jurks but it don't skip gears after 15 minutes drive it stops and shift good it drives good no problem what can cause that any help would be appreciated thanks
Katpwr
Jul 11, 2013 03:35 AM
honda_tuner20
Feb 11, 2010 10:54 PM
