B20 gasket in place of LS gasket?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by be.twenty »</TD></TR><TR><TD CLASS="quote">LS gasket
i'm sure they're the same anyways... </TD></TR></TABLE>Are ALL 94 and up LS intake gaskets the same bolt pattern?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoltonGSR »</TD></TR><TR><TD CLASS="quote">Are ALL 94 and up LS intake gaskets the same bolt pattern?</TD></TR></TABLE>
i replaced my 1999 ls motor for a jdm b20 and used a new ls gasket on the ls manifold. the b20 came with high manifold. it was a bitch and a half to scrape the old gasket off the b20
i'm not sure if the bolt pattern is the same from 94-01 b18b
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoltonGSR »</TD></TR><TR><TD CLASS="quote">Are ALL 94 and up LS intake gaskets the same bolt pattern?</TD></TR></TABLE>???
all non vtec B series intake gaskets are the same, this is why aftermarket manifolds are interchangeable from 90+.
when i need parts for my LS i use pretty much everything from the cr-v, cuz the honda dealer is a half hour closer than the acura dealer, and the ONLY differance is the bore. besides the obvious stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">all non vtec B series intake gaskets are the same, this is why aftermarket manifolds are interchangeable from 90+.
when i need parts for my LS i use pretty much everything from the cr-v, cuz the honda dealer is a half hour closer than the acura dealer, and the ONLY differance is the bore. besides the obvious stuff.</TD></TR></TABLE>Thanks
Novtec4u
Dec 21, 2008 05:47 PM
