98 gsr abs removal **searched**
Old Mar 22, 2007 | 10:48 PM
vtac sonn's Avatar
Default 98 gsr abs removal **searched**
i searched for a thread for abs removal of a 98 gsr and couldnt find anything i was wandering if anyone could help me out with the parts i need or a thread discussing it with a how-to....thanks for any help
Old Mar 23, 2007 | 02:22 AM
dc2_dude's Avatar
get brake lines from a non-abs equiped teg. such as a RS, thats what im doin
Old Mar 23, 2007 | 04:29 AM
hifonics's Avatar
Default Re: (2literteg)
why would you want too take off the ABS?
Old Mar 23, 2007 | 07:22 AM
iUsedToBeFast's Avatar
Default Re: (hifonics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hifonics &raquo;</TD></TR><TR><TD CLASS="quote">why would you want too take off the ABS?</TD></TR></TABLE>
because it blows...... i did it for a buddy i used the rs porpotionate vlave and master cyclinder and all the lines because we had a smashed donor car.
Old Mar 23, 2007 | 07:44 AM
CJ_2Dr's Avatar
Default Re: (iUsedToBeFast)
b/c abs sucks hard, i did not want it so i got a RS.
Old Mar 23, 2007 | 08:48 AM
dc2_dude's Avatar
only reason im doing it is for the tuckage. wire tuck and shaved bays ftw DUH
Old Mar 23, 2007 | 08:57 AM
vtac sonn's Avatar
thats basically the same reason i am wanting to do it
Old Mar 23, 2007 | 09:20 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iUsedToBeFast &raquo;</TD></TR><TR><TD CLASS="quote">
because it blows...... i did it for a buddy i used the rs porpotionate vlave and master cyclinder and all the lines because we had a smashed donor car.</TD></TR></TABLE>
Ever wonder why the donor car was smashed? j/k
ABS helps with braking stability, not stopping distance in most cases.
Old Mar 23, 2007 | 07:48 PM
Default Re: (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
ABS helps with braking stability, not stopping distance in most cases.</TD></TR></TABLE>
the donor car was rear ended at a stop light downtown. with me in the passenger seat.... so thats why it was smashed and abs is horrible even worse in snow.
Old Mar 23, 2007 | 08:15 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: 98 gsr abs removal **searched** (vtac sonn)
https://honda-tech.com/zerothread?id=1930126
Old Mar 23, 2007 | 08:21 PM
PrinceAli132's Avatar
Default Re: 98 gsr abs removal **searched** (CleanLikeJdm)
https://honda-tech.com/zerothread?id=1160671
Ali
Old Mar 23, 2007 | 08:35 PM
black98gsr-t's Avatar
got beat to it ^^^^^^^^^
Old Mar 23, 2007 | 08:46 PM
I AM WEASEL's Avatar
To remove the abs in your car you can go a couple different routs witch all of them are relatively easy. First - and for every way you go - you will need to get a 40/40 proportioning valve from a non abs car like an rs integra or a 99/00 si. Now you can either keep your brake booster and master cylinder and get the two lines from the rs that go from the prop valve to the front two wheels and all you will need to do is bend up two hard lines from the master cylinder to the prop valve or use stainless. Or you can get an rs master cylinder, booster and prop valve and just get the lines from an rs. And it is as simple as that.
Old Mar 23, 2007 | 09:31 PM
vtac sonn's Avatar
thanks for all the input guys...now for the hard part find brake parts for an rs
Old Mar 25, 2007 | 08:15 PM
Default Re: (vtac sonn)
If you are looking for new brake parts for an rs integra there are a few web sites that I know of that you can look at for parts. acuraoemparts.com and acuraautomotiveparts.org and they will have the lines and Master cylinder/booster and prop valve that you are looking for. Or if you are looking for used check your local junk yards/automotive wreckers to see what they have.
Old Mar 31, 2007 | 09:29 AM
vtac sonn's Avatar
Default Re: (JDM se-R)
ok i was talking to a friend that says on a 98 up i can use my stock masyer cylinder and booster...any truth to this???
Old Mar 31, 2007 | 10:59 AM
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtac sonn &raquo;</TD></TR><TR><TD CLASS="quote">ok i was talking to a friend that says on a 98 up i can use my stock masyer cylinder and booster...any truth to this???</TD></TR></TABLE>
Most of the reason in changing those parts, from what I've gathered,
Is you would then need to custom bend some lines.
If you use w/e is listed in the one thread, then you can use all stock pieces.
But if you Can bend lines, or get them bent, then it seems all you need is a prop valve.
Old Apr 2, 2007 | 06:52 PM
Dev15Bizz's Avatar
let me know how it turns out, i hate the abs unit under the hood, never thought of doing that though, BUMP
Old Apr 2, 2007 | 07:05 PM
integrawhat's Avatar
ok few questions first one might be stupid but what the hell does ftw stand for i see it every where and cant figure it out. lol.
second im removing abs for several reasons but not using the stock 40/40 valve anyone know where to get a front/rear adjustable proportioning valve. bending custom lines is about as hard as tying your shoes so thats not a problem i just want to have the ability to adjust my braking if im not going to have abs.
Old Apr 2, 2007 | 07:23 PM
CJ_2Dr's Avatar
Default Re: (integrawhat)
hahahaha FTW= FOR THE WIN!!
good luck on abs, personally never heard of an adjustable prop valve so idk about that, just buy stock rs **** and you will not have any problems, everything would be oem and you would not have abs. idk
Old Apr 3, 2007 | 03:55 PM
vtac sonn's Avatar
thanks guys for all of the input..i couldnt find parts in a junkyard so i ordered them from acura oem parts..i plan on doing a writeup with pics for reference and see if i can get it put in the faq
Old Apr 3, 2007 | 05:56 PM
Default Re: (CJ_2Dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CJ_2Dr &raquo;</TD></TR><TR><TD CLASS="quote">personally never heard of an adjustable prop valve so idk about that,</TD></TR></TABLE>
a guy in my pact program had one on his dc2 and said it would brake from 100-0 completely level with no nose dive at all but uh he sold his car and droped the program so i dont know where he got it
Old Apr 4, 2007 | 04:41 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrawhat &raquo;</TD></TR><TR><TD CLASS="quote">
a guy in my pact program had one on his dc2 and said it would brake from 100-0 completely level with no nose dive at all but uh he sold his car and droped the program so i dont know where he got it </TD></TR></TABLE>
A proportioning valve will not prevent nosedive. That is a function of suspension.
Here is some information on braking systems in general:
http://www.stoptech.com/tech_i...shtml
Old Apr 4, 2007 | 05:12 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
How is ABS worse in the snow? If you lock up your tires on wet or slick streets, stopping distances will be LONGER without ABS. ABS also serves to allow you to steer the car when panic-braking.
If it's dry, then yes locking up your tires will stop you faster than if ABS activated, but then you would also have nice flat spots on your tires.
If you drive your car on public streets, ABS can be very beneficial and can save you from a wreck. Don't say "but I'm such a hardass I don't need ABS" pfffft. Things can happen without warning, everyone gets into a situation where they panic brake and just jam the pedal as hard as they can. You can't prepare yourself for everything that might happen on the road.
If your car is a race car that's one thing, but if you drive on public streets around all the other stupid drivers in this country, I would advise you to keep ABS in the car.
Old Apr 4, 2007 | 06:01 AM
illdb8's Avatar
LOL!! AMEN
ABS is there and was a upgrade for a reason.. Rocking a DB8 leaving mine in.
