Stock Ignition: How to 2 step?
Old Mar 22, 2007 | 10:07 PM
jDMJeRk's Avatar
Default Stock Ignition: How to 2 step?
About to head to the track for the first time this season and I've been wondering what my options are as far as a 2 step would go... I have a distributor king dissy too (seems to be working great... 425/325tq)... Management is Apexi Power FC... (could switch back to a chipped ecu if I had too...)
I basically need something to help me build boost off the line and work as a launch control.
Is there something easier out there besides switching to an aftermarket ignition?
Old Mar 23, 2007 | 03:36 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Stock Ignition: How to 2 step? (jDMJeRk)
you either need an ecu with launch control, a 2 step on my car with the t3t67ho, at 8200rpms, i only got 8 psi. so to build good boost you need something with antilag. either way you need an ecu with anti lag, or launch control, or an ignition box with provisions for a 2 step.
Old Mar 23, 2007 | 05:06 AM
smokey2.0's Avatar
Default Re: Stock Ignition: How to 2 step? (boostedcivicsir)
when i spoke with the people at msd, they told me that i had to use a tach signal unit that they sell(i don't remember the part# right now) in order to be able to use their two/three step modules without an ignition box!
Old Mar 23, 2007 | 08:21 AM
HybridKOOP's Avatar
Default Re: Stock Ignition: How to 2 step? (smokey2.0)
The key to a two step is to be able to retard timing (a ton of it) along with your rev limit, and the functionality to cease once you've launched.
You can buy an external box setup for it, or you can use an ECU that incorporates it internally. There's no "work around" for it. You need one or the other.
Old Mar 23, 2007 | 08:32 AM
NJcoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">when i spoke with the people at msd, they told me that i had to use a tach signal unit that they sell(i don't remember the part# right now) in order to be able to use their two/three step modules without an ignition box!</TD></TR></TABLE>
Anymore info on just using the tach adapater and a 2/3 step box?
Old Mar 23, 2007 | 08:55 AM
vaporboy12's Avatar
Default Re: Stock Ignition: How to 2 step? (idriveacoupe.)
you need some kinda of igntion cut via a ignition box
92LXcb7
Feb 24, 2012 11:58 AM
VeeL_B20
Nov 14, 2007 07:32 PM
tyflip2
Nov 27, 2003 12:02 PM
