B20/VTEC head gasket trouble:
Building a B20B block / B18C1 head combination and wanted to be sure what HG to use. I called Race Engineering (Cometic dealer) and the guy I spoke with said I need to match the gasket to the HEAD (GSR), but everything else I've seen says I should be running a gasket to match the BLOCK. Help me out here!
Just to add to this - I'm looking at Race Engineering's list of HGs right now and they DO have a "B18C / B16A" 84mm head gasket but they do not appear to have a B20 head gasket anywhere. I know the dowel pins won't line up on a VTEC head gasket so what should I do?
you can just use a stock honda crv headgasket, it'll be fine but if you had the block bore/hone to 84.5mm, you can just use a 85mm cometic headgasket
Yeah I was a little scared when the Race Engineering guy was pointing me in the wrong way, but it looks like Cometic has already addressed CRVtec engines and they're selling a HG specifically for such a conversion.
El Veterano de Sur Califas
if u bore your b20 to 85mm, then yes u gave to get the cometic 85mm b20 hg. Now if you have 84.5 mm pistons, than u can use stock hg, becasue the stock hg when crushed actually opens to 84.5mm. I highly doubt that stock hg come 1mm over.
manny
manny
crv-techu
Mar 11, 2006 04:05 PM
