aem wideband
Old Mar 22, 2007 | 06:27 PM
b18_racer805's Avatar
Default aem wideband
taken care of contacted aem and they said just to buy the new harness thanks for the help
Modified by b18_racer805 at 11:44 AM 3/23/2007
Old Mar 22, 2007 | 07:35 PM
A.E Motoring's Avatar
Default Re: aem wideband (b18_racer805)
pm sent
Old Mar 22, 2007 | 08:50 PM
http://i94.photobucket.com/alb...9.jpg
http://i94.photobucket.com/alb...8.jpg
http://i94.photobucket.com/alb...7.jpg
http://i94.photobucket.com/alb...5.jpg
i was wonder if it was possible to cut off the plug on the sensor one since i baught a new sensor and sauder them together
Old Mar 22, 2007 | 08:59 PM
Boilermaker1's Avatar
if you have the connector that goes into the back of the gauge, then yes, you can hack the connector off. I did, the damn connector is so big it wouldnt go through the firewall, so we cut it off and put a spade connector on each wire then heat shrinked it together.... much smaller, which went through the firewall grommet without having to make a new hole. Just match color to color on each side
Old Mar 22, 2007 | 09:20 PM
Default Re: (Boilermaker1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boilermaker1 &raquo;</TD></TR><TR><TD CLASS="quote">if you have the connector that goes into the back of the gauge, then yes, you can hack the connector off. I did, the damn connector is so big it wouldnt go through the firewall, so we cut it off and put a spade connector on each wire then heat shrinked it together.... much smaller, which went through the firewall grommet without having to make a new hole. Just match color to color on each side</TD></TR></TABLE>
PM YOU BRO
Old Mar 23, 2007 | 03:16 AM
rmcdaniels's Avatar
Old Mar 23, 2007 | 08:27 AM
JohnnyLawless1
Nov 21, 2013 04:42 PM
allmotorpackage
Mar 5, 2012 12:52 PM
BoostedJeff
Oct 18, 2004 05:46 PM
EGfastback22R
Feb 16, 2004 04:54 PM
