ITR P73 problem
Im trying to get my car to pass somg I ordered a P73 ecu so the smog station can read the car I have a 2000 ITR
the ecu i got is 37820-P73-A04
I installed it and the car didnt want to turn over? any advise would be great! thx 4 your time !
no i didnt get a key made with it when I bought it the person selling it said its for a USDM ITR and 200 itr would work with it thanks for your info gusif more please help thx!!
you can remove imobilizer chip from ecu but.. it will fail due to check engine light. i think theres a way to bypass that so you do not get cel i sure dont know how to.
the only way to make that ecu work and not throw cels is.. to go to dealer and have them reprogram that ecu to work with your ignition. call them up and aks someone who knows
these guys can remove the immobilizer for $55usd ->http://www.ff-squad.com/ecu/imm.removal.htm
If you think a usdm 94'OBD1 p72 will work I can let you borrow mine as Im being deployed for a couple weeks soon(I'd want to hold something of equal value during the time I'd be lending it).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stolen_rims »</TD></TR><TR><TD CLASS="quote">these guys can remove the immobilizer for $55usd ->http://www.ff-squad.com/ecu/imm.removal.htm
You can remove it yourself with basic soldering knowledge. Their method is nothing special, it even states in their FAQs that there will still be a CEL.
"Once an IMM is removed you will have a constant check engine light, because the factory programming is designed to look for the IMM, and now that it's been removed, it throws a check light letting the driver know something has changed."
turkdog
Nov 30, 2003 06:15 AM
bypass, im, immobiliser, immobilizer, immobilzer, immobolizer, itr, jdm, p73, p73a04, pass, problems, removal, remove, smog, usdm
