Honda S2000 Honda S2000
how do i reset my oil life?
Old Mar 22, 2007 | 01:02 PM
patricks2000's Avatar
Default how do i reset my oil life?
like the topic says i just wanted to know how do i reset my iol life on my 2006 s2000. thanks
Old Mar 22, 2007 | 01:05 PM
LAS2K's Avatar
Default Re: how do i reset my oil life? (patricks2000)
https://honda-tech.com/zerothread?id=1917945
search FTW
Old Mar 22, 2007 | 01:38 PM
IN VTEC's Avatar
For 2006+ models with the maintenance minder system:
Resetting the Maintenance Information Display
NOTE: The vehicle must be stopped to reset the display. You might also need to have the parking lights and headlights turned off too, but that might only applicable to the older MAIN'T REQ'D lights.
If a required service is done and the display is not reset, or if the maintenance display is reset without doing the service, the system will not show the proper maintenance timing.
This can lead to serious mechanical problems because there will be no accurate record of when the required maintenance is needed.
PROCEDURE:
1.) Turn the ignition switch to the ON (II) position.
2.) Press release the TRIP button repeatedly until the engine oil life indicator is displayed.
3.) Press and hold the TRIP button for about 10 seconds.
4.) The engine oil life indicator and the maintenance item code(s) will blink. Let go of the TRIP button.
NOTE: If you are resetting the display when the engine oil life is more than 15 %, make sure any maintenance item(s) requiring service are done before resetting the display.
5.) Press and hold the TRIP button for another 5 seconds. The maintenance item code(s) will disappear, and the engine oil life will reset to ''100''.
6.) The maintenance item code(s) will disappear, and the engine oil life will reset to ''100''.
Whatislove
Honda Civic (2001 - 2005)
May 7, 2009 11:31 AM
caseyjholmes
Honda S2000
Apr 30, 2007 10:20 AM
caseyjholmes
Honda S2000
Feb 25, 2007 09:54 PM
jo3blo3
Honda Civic (2006 - 2015)
Sep 15, 2006 07:45 AM
TheGSRGuy
Oct 30, 2005 11:28 AM
