weird fuel pressure problem... 0psi during prime, 40psi at idle
Old Mar 22, 2007 | 10:46 AM
BlackCRX's Avatar
Default weird fuel pressure problem... 0psi during prime, 40psi at idle
boosted stock y8
stock fpr/rail, dsm 450's, walbro 255 intake
i noticed that now when i prime the motor the fuel gauge shows 0psi
when i start the car it shows and stays at 40psi
i pull the vacuum line from the stock fpr and it raises to 50-51psi
so this leads me to think that the fpr is ok right?
when i shut off the car the fuel pressure drops instantly
i remember before i would prime the fuel system and it would hold at 40psi, and when i shut off the motor it would hold fuel pressure at 40psi for some time before going down
i asked another friend he was saying it has to do wi the walbro fuel pump and the return valve
my friend suggested i should replace the pump, but alot of other ppl i have talked to with walbro;s have the same problem and they just ignore it
since i own a crx i really dont want to drop the tank to get to the pump, but at the same time will this cause a problem holding stable fuel pressure under boost?
thanx for everyones help
Old Mar 23, 2007 | 12:19 PM
BlackCRX's Avatar
anyone?
Old Mar 23, 2007 | 01:48 PM
trickeng's Avatar
Default Re: (BlackCRX)
do you hear the pump turn on before you start it?
Old Mar 23, 2007 | 02:15 PM
BlackCRX's Avatar
yup, the pump whines like a bitch when i prime it
092eg6
Dec 11, 2009 01:36 PM
91tealhatch
Nov 3, 2008 07:10 AM
UNKNOWN_MEMBER
Aug 16, 2005 01:29 AM
VNTEC
Jul 6, 2004 06:45 AM
