changing rotor need help?
i have a haynes manual but im 400 miles from home right now and notice 1 side of my rotor is warped/scratch...and wanna change it before i get on the highway again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KingDanOne »</TD></TR><TR><TD CLASS="quote">take off the caliper and there should be to scres on the rotor... tkae them out and ....wahlah...</TD></TR></TABLE>
Engrish?
Here, this may help: http://spoon.org/civic/DIY-Brakes/
Engrish?
Its pretty easy.
1. Remove the two bolts holding the caliper to the wheel hub. Don't let the caliper dangle by the brake line (you can bend up metal clothes hangers to help keep some slack).
2. Remove the screws from the front of the rotors.
3. Replace with new rotor.
4. Remove brake pads from caliper.
5. Bolt caliper back onto hub.
6. Unbolt bottom caliper pivot bolt and swing outer portion of caliper up.
7. Install new brake pads.
8. Compress caliper piston using old brake pad and C-clamp.
9. Swing caliper back down and reinstall pivot bolt.
10. Clean rotor with brake fluid cleaner to make sure surface has no brake fluid or dust that could contaminate pad.
Repeat for opposite side.
When finished, start car and pump brakes a few times to build up pressure lost from compressing piston with clamp. Follow brake pad bedding instructions (usually 8-10 times of speeding to 30mph for 1 min, brake to 0 over 3-5 seconds and repeat),
From: Close to West Chester, PA, United States of America
Repeating this for the green...
You NEVER do just one side. You always do this stuff in pairs. So BOTH front, or BOTH rears... Fronts do ~70% of the braking so I guess you could get away hacking the rear temporarily, but for the fronts... don't mess around, do BOTH.
p3
and
doing it yourself.
p3
and
doing it yourself.
thanks for the info guys i finished and its ready new brembo rotors and some pep boy pads..also cured my freeway braking vibration...
