SeaFoam on a Jdm H22a?
I want to know if i should use or need to use sea foam on my jdm h22a, im not sure because it only has 27XXX miles on it? And if Yes is there a write up on how to use it on 4th gen preludes?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lukieluc »</TD></TR><TR><TD CLASS="quote">I want to know if i should use or need to use sea foam on my jdm h22a, im not sure because it only has 27XXX miles on it? And if Yes is there a write up on how to use it on 4th gen preludes?</TD></TR></TABLE>
how do u know it only has 27,xxx miles? just because homotors said it did, doesnt mean its true
I didn't buy my motor from hmotorsports I bought it from Tigerjapanese.com, & they provided me with proof that it had 25000 miles when I bought it. Would it hurt the motor if I used sea foam?
You only need seafoam on engines that need it, not one's that don't.
Also for the writeup, just pickup a can and look at it and get all the writeups you could ever need.
yeah btw, you shouldn't use it unless you have atleast a couple hundred thousand kilometers. its for older engines with carbon buildup. your 27000 motor hasn't even broke its virginity yet
JBirch_97Prelude
Apr 28, 2007 11:03 AM
tim.simpson
Dec 25, 2001 10:36 AM
