Replacing Ground Wires????
Old Mar 22, 2007 | 09:10 AM
LukieLuc's Avatar
Default Replacing Ground Wires ?'s
I wanted to know what gauge wire should i use to replace the ground wire from the battery to the fuse box? i was thinking like 4 Gauge, is that thick enough or should i go with 0? i also want to know what size wires do i use to replace the ones connecting to the tranny and the head of the motor ground wires?
Are these wires good enough to replace the grounds?
http://stores.ebay.com/Bag-Boy...QtZkm
And what do you guys think about replacing my battery with a odyssey 680 battery? Does anyone have a write up on this?
Old Mar 22, 2007 | 09:20 AM
DarkBB4's Avatar
Default Re: Replacing Ground Wires ?'s (lukieluc)
4 gauge will be fine
evbecks.com --->DIY---> Odyssey 680 install
ur welcome
Old Mar 22, 2007 | 10:41 AM
mattsnooz's Avatar
4 awg would be large enough to do 60% of the bonding(grounding) in your car. For motor bonding i would use 0 and your fuse box i would use 0. They both have high current demands at some points and therefor if a fault occurs the larger the ground the less resistance the current has to flow away from your critical parts. Also, are alot of your wires corrodedor something? if so i'd also check the transmission ground aswell.
Modified by mattsnooz at 1:13 PM 3/22/2007
23LX23
10
Nov 19, 2016 06:08 PM
stevenr2894
10
Mar 9, 2013 10:23 AM
lilo_goki
Aug 22, 2008 03:46 PM
redman223
Audio / Security / Video
May 4, 2007 02:51 PM
Full Race A6
Jan 30, 2004 08:38 AM
