Fuel filter install
Old Mar 22, 2007 | 05:40 AM
TMC_EF's Avatar
Default Fuel filter install
can some one tell me how to install a fuel filter in a ef SEDAN
Old Mar 22, 2007 | 05:48 AM
Loserkidwac's Avatar
Default Re: Fuel filter install (TMC_EF)
Get some rags....place them around the furl filter...loosen the small bolt thats on the top of the feed line(line from the filter to the fuel rail, bolts ontop of the filter) that releives fuel pressure...now all you need to do is remove the fuel lines from the top of the filter, remove the filter from the firewall...replace with the new one, make sure you use the new copper washer/gaskets that come with the new filter and that the old ones aren't stuck to the fuel lines...put fuel lines back on, then I'd prime the car a fe times...pull the dizzy plugs or something and just let the car turn over a few times to let the fuel filter fill up and the fuel pressure...then start the car and your done
Old Mar 22, 2007 | 05:59 AM
TMC_EF's Avatar
Default Re: Fuel filter install (Loserkidwac)
Thanx
Old Mar 22, 2007 | 11:45 AM
Tyson's Avatar
relieve the pressure first by removing the gas cap.
youll still get some leakage when you loosen the banjoy bolt, but it wont be nearly as bad.
Old Mar 22, 2007 | 12:05 PM
Default Re: Fuel filter install (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">relieve the pressure first by removing the gas cap.
youll still get some leakage when you loosen the banjoy bolt, but it wont be nearly as bad.</TD></TR></TABLE>
Good tip, never though of that
Old Mar 22, 2007 | 12:42 PM
Tyson's Avatar
its in the helms!
Old Mar 22, 2007 | 12:44 PM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">its in the helms!</TD></TR></TABLE>
Yeah, step one for anything involving the fuel system.
Well, and common sense too (at least to me).... that sucking sound when you take the gas cap off is because the system is depressurizing as you've released the vaccuum in the tank.
Old Mar 22, 2007 | 12:56 PM
Default Re: Fuel filter install (wiZCo)
I always just used the bolt on top of the filter to relieve the pressure...who read manuals anyways...
Old Mar 22, 2007 | 01:07 PM
Tyson's Avatar
RTFM!
redlinez_r_us
Sep 16, 2009 12:02 PM
Re3irth
25
Jun 27, 2009 06:40 AM
91CiviHatch
11
Nov 10, 2008 02:41 PM
CivilizedCiv
Aug 22, 2002 08:22 AM
samdawgsol
May 13, 2002 09:40 AM
