Honda Engines in the rear???
Old Mar 22, 2007 | 04:54 AM
96civich22's Avatar
Default Honda Engines in the rear???
OK i have seen a couple people putting honda engines in the rear of cars and making them rear wheel drive. I know how the honda transmission work, stablizer bar then the rod that actually shifts the transmission.
so when these guys put the engine in the rear how do they get the transmission to work? i cant figure it out for anything.i thought i figured it out but it didnt work out.
can someone help me out cause this is screwin up my head.
Old Mar 22, 2007 | 05:36 AM
tec_wiz's Avatar
Default Re: Honda Engines in the rear??? (96civich22)
the easiest way is to use a h series motor and trans since they have cable shifters.
Old Mar 24, 2007 | 03:36 AM
4dooritr's Avatar
no i wouldnt like a honda engine up my rear end... i swear ppl on h-t these days
Old Mar 26, 2007 | 11:47 AM
96civich22's Avatar
Default Re: Honda Engines in the rear??? (4dooritr)
thanks for the great coment...NOOB
anyways the reason i ask, is that i was looking at the original atom and i cant figure out how the b-series is working in the back
Old Mar 28, 2007 | 04:14 PM
Wes V's Avatar
It's done by fabricating up some sort of bell-crank.
Wes
Old Mar 28, 2007 | 04:33 PM
EG2Driver's Avatar
Default Re: Honda Engines in the rear??? (Wes V)
If it was a B-Series, which turns counter clockwise, it would not work. You'd have 5 reverse gears, hence they used the K-Series which goes the other way, plus its cable so its possible to mount a custom bracket and make it work.
Old Mar 28, 2007 | 05:41 PM
dfoxengr's Avatar
Default Re: Honda Engines in the rear??? (DeadEnd9009)
bseries would work facing its normal way.
shifting done by linkages and cables.
Old Mar 28, 2007 | 05:51 PM
EG2Driver's Avatar
Default Re: Honda Engines in the rear??? (dfoxengr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">bseries would work facing its normal way.
shifting done by linkages and cables.</TD></TR></TABLE>
im just saying its a lot harder to make work than a K because of the shifting done with rods.
Old Mar 28, 2007 | 05:56 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 &raquo;</TD></TR><TR><TD CLASS="quote">If it was a B-Series, which turns counter clockwise, it would not work. </TD></TR></TABLE>
yeah.
kieranmhalton
Jun 11, 2013 05:00 PM
no show no go
Aug 3, 2007 12:20 AM
