Making t25 fix on d16y8!?!?!?!?
hey i have a 97 ex civic and just picked up a t25 off of a saab from a junkyard my question is how do most ppl make them fix because i know most of the turbo manifolds have t3 flanges do you guys go with a adapter plate from a machine shop or wat ive just heard there expensive to be made or i accually found a t2 to t3 adapter flange on ebay but dont know if it would work cuz its from ssautocrome thanks???
i have a t25 manifold for the d16 if you want, never used. selling for 200obo
https://honda-tech.com/zerothread?id=1901794
nah its the same rectangle shape but its about a quater to half inch smaller the flange that is and my turbo does have the wastegate but idk wat psi its set at and i might want to change it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bkmc24 »</TD></TR><TR><TD CLASS="quote">IM pretty sur t25's have T3 flanges.
and if you got one off a saab, isnt it internally wastgated?</TD></TR></TABLE>
T25's will either use a T2 flange, or a gay proprietary flange from the auto mfg.
The way most people get t25's to work is by using an HF manifold + adatper plate, a log/ramhorn manifold with t25 flange, or the hks/greddy manifolds (they use the t25 flange). There simply isn't enough room in a civic's engine bay to use a t3-t25 adapter plate. The only way it would work is with t25 and t3 flanges welded together, studs put in each side, and a manifold that had through-holes in the manifold that you can use nuts with. Usually that means ssautcrome, ramhorn, minime/elf, or a log with the flange extended out a bit. Either unreliable, expensive, or just not easy to find.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile »</TD></TR><TR><TD CLASS="quote">
The way most people get t25's to work is by using an HF manifold + adatper plate, a log/ramhorn manifold with t25 flange, or the hks/greddy manifolds (they use the t25 flange). There simply isn't enough room in a civic's engine bay to use a t3-t25 adapter plate. The only way it would work is with t25 and t3 flanges welded together, studs put in each side, and a manifold that had through-holes in the manifold that you can use nuts with. Usually that means ssautcrome, ramhorn, minime/elf, or a log with the flange extended out a bit. Either unreliable, expensive, or just not easy to find.</TD></TR></TABLE>
Well im pretty sure the T25 i had off the SR20 from my brothers car had a t3 flange chief
boostedblack99
May 27, 2003 08:27 PM
