help with my integra console
Old Mar 21, 2007 | 11:54 PM
1991hb's Avatar
Default help with my integra console
First of all this pic is not of my car.
I put a integra console in my '88 HB and it looks great except for one thing. Notice the screws that I circled in red. That part hangs down a little bit in my car. I don't want to screw it in like this pic shows unless I have to. Is there a way to keep it up without screwing it in like this. It just looks kind of tacky with the screws showing. Thanks for any help.
Old Mar 22, 2007 | 04:54 AM
janz3n's Avatar
Default Re: help with my integra console (1991hb)
ya mine hangs low aswell.. but nothing noticable. is there anyway of screwing it from inside the ashtray part? probably too tight for that.you could always use some glue or silicone.
Old Mar 22, 2007 | 05:01 AM
90civichbsi's Avatar
Default Re: help with my integra console (janz3n)
I screwed mine in on the sides similiar to stock just drilled thru the metal frame and anchored it with a screw there. it fits snug. i can post pictures later today once i make it home if you want
Old Mar 22, 2007 | 07:19 AM
grog's Avatar
Default Re: help with my integra console (90civichbsi)
yes, i scewed that area from the back side. I used a little peice of plastic to connect the two peices, its like 1 inch long with holes to line up with the screw locations on both peices. mine does'nt sag and theres no visible screws on the front. hard to explain without photos, but if you have it out of tha car it will be clearer. good luck
Old Mar 22, 2007 | 09:31 AM
1991hb's Avatar
thanks for the help and ideas guys
Old Mar 22, 2007 | 04:13 PM
grog's Avatar
Default Re: (1991hb)
do you have both peices out of the car? this is important. theres alot of old threads on this btw.
Old Mar 22, 2007 | 04:45 PM
janz3n's Avatar
Default Re: (grog)
just try putting silicone behind the piece.. let it sit for a day or maybe just a few hours to let it dry and put it back into your car.. you'll have to take the whole thing out though..
Old Mar 22, 2007 | 07:02 PM
My_EFsedan's Avatar
Default Re: (janz3n)
that pix, mines just like that. with thte 2 screws. but i removed my console and replace with the stock one.
Old Mar 22, 2007 | 07:46 PM
crxcess's Avatar
Default Re: (My_EFsedan)
could you use velcro strips?
Old Mar 23, 2007 | 04:41 AM
janz3n's Avatar
Default Re: (crxcess)
you can use anything that will work.
just because im bored heres mine. my ashtray part still hangs low like that but i dont want to put screws in it either.. and im too lazy to take it out again.
cb hatch
May 14, 2008 09:02 AM
AmyRW
Apr 1, 2008 09:46 AM
Rease3
Aug 12, 2007 03:48 AM
RGoose18
Audio / Security / Video
Jun 7, 2006 02:17 PM
EFSi
11
Jul 2, 2002 01:19 PM
