hf dx or si
so i was wondering i no i have to get the same model year chassis harness for my crx but i was wondering if the chassis part has to be model specific? cause i cant seem to find any dx chassis harness and i found an si one on crx community so any help so i dont get ripped off would be sweet!
if your replacing the ENTIRE harness then you can use hf or si to avoid converting to mpfi, but dx chassis harness is not compatible with si engine harness...etc....etc...
o im not using the si engine harness i just need to get the chassis harness adn then im buying the rest from rywire for my b16a conversion, so what im understanding is i can use the si chassis harness without problems in my dx, besides if i was using the the same engine harness
u have to use the same harness as your body or u will heave problems trust me i tryed the problem is when u have your motor harness made u send in the motor harness from both motors and they make u one to fit your car if you need a dx harness i got one
well i talked to rywire today they said an si chassis harness would work to i just need to send in my b16 engine harness and the si one to make it work, but how much do you have the dx one for? cause i found an si one on crx community for 230.00 how much would yours be?
1 Fly SI
Nov 9, 2006 11:51 AM
HondaHeddie
27
Oct 6, 2006 07:57 PM
Argetnia
Apr 7, 2005 11:54 PM
mobrep
Jan 5, 2004 05:31 AM
