Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Distributor O-ring replacement
Old Mar 21, 2007 | 08:47 PM
WVhump's Avatar
Default Distributor O-ring replacement
My 1995 2.5L 5 Cyl Honda Inspire/Acura TL is leaking oil through the distributor. I changed one O-ring on the distributor but understand that there are two. Any help?
Old Mar 22, 2007 | 07:03 PM
Kenso's Avatar
HT White Ops
Default Re: Distributor O-ring replacement (WVhump)
There is a seal inside the distributor housing on the shaft itself that often leaks. It's not available separately, you have to buy the whole dist. housing. (unless you want to tear it down yourself and try and match it up with something).
Old Mar 24, 2007 | 03:51 AM
WVhump's Avatar
Default Re: Distributor O-ring replacement (Kenso)
Thanks for the info. I may try to change that 0-ring on the distributor shaft.
Old Mar 24, 2007 | 07:25 PM
Aahj's Avatar
it's not an o-ring...it's a seal. If you're going to do the job, it would be wise to have new distributor ready.
Good luck,
AJ
Old Mar 25, 2007 | 12:59 AM
WVhump's Avatar
Default Re: Distributor O-ring replacement (Aahj)
Thanks for saving me alot of trouble. The Honda dealer sold me 2 o-rings. I installed one and went to return the other one and the parts guy said that the distributor took two o-rings. He said it took a while before their own mechanics realized this. Anyway, if its a seal rather than an o-ring & you recommend I have a replacement distributor ready, I think I'll live with the leak awhile longer. Thanks again for your help.
Old Mar 28, 2007 | 12:22 PM
u n v kenny's Avatar
#7 is the main one that usually needs replaced.
Old Mar 28, 2007 | 10:30 PM
WVhump's Avatar
Default Re: Distributor O-ring replacement (unvdis)
Man, you guys are good. Thanks for the help.
Vtec_India
Feb 15, 2016 10:15 PM
mellowman164
Jan 12, 2014 10:59 PM
themiz816
Apr 28, 2013 07:16 PM
tca0bell
Oct 18, 2006 04:16 PM
