Teg ecu w/D16Z6
I was wondering if you could you an integra PR4 ecu to run a D16Z6. I know i would need a vtec controller to make it work. But a friend told me this would work an i wanted to know if anyone has ever tried it. It would run fairly rich i think but that would be could for it when i turbocharge it right?
yes you can do it, i have done it, but the only thing is that when the vtec kicks in the fuel curve doesnt change like a fatory vtec computer.
hope this helps
brian
hope this helps
brian
right now i am using a p28 ecu from a 92-95 civic si hatch back or the EX. and yes you will have to use a vafc to activate the vtec, because that teg computer does not have the wiring for vtec
brian
brian
So couldnt i use the VAFC to adjust the fuel for the vtec when using the pr4? I want to find a p28 but everybody wnats a p28 and they are getting expensive.
