Running a stock bore 75mm HG on a 75.5mm cylinder bore
Old Mar 21, 2007 | 05:01 PM
unknown0001's Avatar
Default Running a stock bore 75mm HG on a 75.5mm cylinder bore
hey guys, I'm having a z6 overbore'd to 75.5mm for a stock rebuild I'm doing.
Just wondering...with the cylinder walls enlarged by .5mm, would I still be able to use a factory bore 75mm head gasket?
thanks
Old Mar 21, 2007 | 05:55 PM
ExospeedAMcrx's Avatar
Default Re: Running a stock bore 75mm HG on a 75.5mm cylinder bore (Mr.RHTuner)
yes should be ok.
Old Mar 22, 2007 | 04:05 PM
Rocket's Avatar
Default Re: Running a stock bore 75mm HG on a 75.5mm cylinder bore (exospeedAMcrx)
How big is the chamfer on the top of your cylinders?
ITRnorway
Sep 1, 2006 02:21 PM
Gant
May 28, 2005 08:10 PM
ItzTw
Feb 24, 2005 04:24 PM
quik1
May 29, 2004 04:25 PM
THE *FOB* MOB
May 23, 2002 02:11 PM
