Compression Tested Today :(
It was a normal day nothing out of the ordinary ,so I thought, and it was turning out to be a good evening. GO home and realize *hey I hav not done a compression test on my car, 92 prelude, for 3 months*
Soooo. I went out and found 155-160-60-160. I was shocked
Soooo.I poured a little motor oil in bad cyclinder and it went up 5 psi.
Should 5psi really matter or should I be looking for a bent valve ?
Soooo....<--still in shock
sounds like a burnt valve or could be a head gasket...if it were the piston rings, the number woulda gone up a lot more than 5 psi when you poured oil in it.
everything happens for a reason...think of it as a good time to upgrade
nemesis25
Jan 12, 2015 04:17 PM
