oil leak!!!
Old Mar 21, 2007 | 01:20 PM
jdmyoo's Avatar
Default oil leak!!!
there seems to be an oil leak from under the dizzy or a sensor under there. are there any commom problems with oil leaks there and does any1 no wat i need to get to fix it. cheers
Old Mar 21, 2007 | 01:45 PM
96 EJ8's Avatar
Default Re: oil leak!!! (jdmyoo)
what kind of motor is this? DOHC or SOHC? on my B18 i had that problem and it was from the cam seal
Old Mar 21, 2007 | 01:46 PM
jdmyoo's Avatar
Default Re: oil leak!!! (integra DA9)
sorry.. its a d15 SOHC. eg 1995.
Old Mar 21, 2007 | 01:47 PM
96 EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmyoo &raquo;</TD></TR><TR><TD CLASS="quote">sorry.. its a d15 SOHC. eg 1995. </TD></TR></TABLE>
im not too familiar with sohc but it should still have the cam seal gasket under the dizzy, check if thats where the leak is coming from.
jdmyoo's Avatar
will doo cheers.
Old Mar 21, 2007 | 01:50 PM
Chim Chim's Avatar
It's usually your distributor O-Ring Gasket... Costs a dollar online and anywhere from 5 - 7 at your local honda parts desk...
Old Mar 21, 2007 | 01:53 PM
jdmyoo's Avatar
Default Re: oil leak!!! (Chim Chim)
how do i find out. which is leaking. its hard to c were abouts its coming from
thanks 4 input
Old Mar 21, 2007 | 02:12 PM
Chim Chim's Avatar
That's the only thing that will leak and collect oil under the dizzy on a SOHC... Since we don't have a second cam, there's no cam seal to worry about... The distributor O-Ring is essentially the cam seal since the camshaft is what drives the dizzy. If it was your valve cover gasket, that would be pretty easy to spot.
Easiest way to check is to pull the whole distributo off (3 12mm bolts) and see how much gunked up oil you have built up. While you're there, check the condition of the said O-Ring and you'll probably find it a bit shrunken for the groove it sits in a it will probably flat instead of round...
Old Mar 21, 2007 | 02:22 PM
96 EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chim Chim &raquo;</TD></TR><TR><TD CLASS="quote">That's the only thing that will leak and collect oil under the dizzy on a SOHC... Since we don't have a second cam, there's no cam seal to worry about... The distributor O-Ring is essentially the cam seal since the camshaft is what drives the dizzy. If it was your valve cover gasket, that would be pretty easy to spot.
Easiest way to check is to pull the whole distributo off (3 12mm bolts) and see how much gunked up oil you have built up. While you're there, check the condition of the said O-Ring and you'll probably find it a bit shrunken for the groove it sits in a it will probably flat instead of round...</TD></TR></TABLE>
nice i learned something today
Old Mar 24, 2007 | 03:24 AM
jdmyoo's Avatar
cheers mate it fix it
honda305
Feb 6, 2008 11:59 AM
Ha Itz
Jan 2, 2007 05:57 PM
PearlWhiteAccord
Feb 24, 2005 08:23 AM
PearlWhiteAccord
Jan 15, 2004 03:07 PM
