sohc vtec and turbo parts
Old Mar 21, 2007 | 11:29 AM
vtec94civic's Avatar
Default sohc vtec and turbo parts
spark racing turbo mnifold ( looks like ssauto mani, but the guy i bought it from said it was a spark racing one)- $120
tial 38mm wastegate- $110
2.25" charge pipes for eg with turbo xs bov, silicone couplers and t bolt clamps- $130
garret t3/t04e .57 trim (.48 a/r exhaust, .50 a/r compressor). needs rebuils still boosted 19-20 psi fine but leaking oil and has some shaft play- $250
rc 750cc saturated injectors- $200
d16y8 block, notched for h beams, kms block guard in good condition never burned oil or smoked( driverside mount holes were helicoiled but is in good condition)- $100
d16y8 oil pan tapped for drain w/ fitting- $75
vitara pistons with pins about 7k on them- $100
probe i beam rods w/ arp rod bolts- $200
d16y8 oil pump less than 5k on it- $40
d16y8 head cyl#4 spark plug threads need to be rethreaed only, plug still screws in just stops half way down. car still ran fine like this- $100
ngk blue wires for sohc vtec- $40
motorola 2.5bar map- $20
2.5" downpipe with 3 bolt flange and 5 bolt adapter $75
voodoo vacuum log- $20
autometer boost and egt gauge black face- $40/$80
cca 28"x6"x2.5" intercooler 2.5" outlet/inlet- $100
d16z6 tranny no grinds, perfect- $200
clutch specialties stg.2 clutch w/ solid hub clutch disc about 75% left- $120
d16y8 arp head studs- $75
-3 or -4 oil feed line from tunertoys with block tee- $30
d series mounts, shift linkage, starter and axles- make offer
i will let everything go for $1600 save almost $700.
paypal add 3%, prices do not include shipping, buti will try to be as reasonable with shipping prices as possible.
also looking to tradefor b series parts/ motor and i am also looking for a buddy club spec 2 exhaust.
Old Mar 21, 2007 | 11:48 AM
bump
Old Mar 21, 2007 | 03:56 PM
ttt
Old Mar 21, 2007 | 04:18 PM
iinvazionii's Avatar
pm'd
Old Mar 21, 2007 | 05:07 PM
Laserjock's Avatar
Default Re: sohc vtec and turbo parts (vtec94civic)
what is the condition of the block?
is it complete with the crank and girdle?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec94civic &raquo;</TD></TR><TR><TD CLASS="quote">
Old Mar 21, 2007 | 06:24 PM
the block does have the girdle. i can include the pump and oil pan if you want but it will be little bit more. the block is in good condition but the crank is probably no good since i spun a rod bearing. i'll let the block go with the pump and pan for $175
Old Mar 25, 2007 | 04:03 PM
i'm willing to let everything go for $1,000 or trade for an ls motor and tranny.
2000civ
16
Sep 13, 2012 07:15 PM
vtec94civic
Mar 26, 2007 08:22 AM
srv3fender
Apr 11, 2005 09:10 AM
awalk2005
Oct 4, 2004 06:26 PM
kingofkingz
Jun 26, 2004 07:04 PM
