SOHC VTEC and Turbo parts
Old Mar 21, 2007 | 11:14 AM
vtec94civic's Avatar
Default SOHC VTEC and Turbo parts
spark racing turbo mnifold ( looks like ssauto mani, but the guy i bought it from said it was a spark racing one)- $120
tial 38mm wastegate- $110
2.25" charge pipes for eg with turbo xs bov, silicone couplers and t bolt clamps- $130
garret t3/t04e .57 trim (.48 a/r exhaust, .50 a/r compressor). needs rebuils still boosted 19-20 psi fine but leaking oil and has some shaft play- $250
rc 750cc saturated injectors- $200
d16y8 block, notched for h beams, kms block guard in good condition never burned oil or smoked( driverside mount holes were helicoiled but is in good condition)- $100
d16y8 oil pan tapped for drain w/ fitting- $75
vitara pistons with pins about 7k on them- $100
probe i beam rods w/ arp rod bolts- $200
d16y8 oil pump less than 5k on it- $40
d16y8 head cyl#4 spark plug threads need to be rethreaed only, plug still screws in just stops half way down. car still ran fine like this- $100
ngk blue wires for sohc vtec- $40
motorola 2.5bar map- $20
2.5" downpipe with 3 bolt flange and 5 bolt adapter $75
voodoo vacuum log- $20
autometer boost and egt gauge black face- $40/$80
cca 28"x6"x2.5" intercooler 2.5" outlet/inlet- $100
d16z6 tranny no grinds, perfect- $200
clutch specialties stg.2 clutch w/ solid hub clutch disc about 75% left- $120
d16y8 arp head studs- $75
-3 or -4 oil feed line from tunertoys with block tee- $30
d series mounts, shift linkage, starter and axles- make offer
i will let everything go for $1600 save almost $700.
paypal add 3%, prices do not include shipping, buti will try to be as reasonable with shipping prices as possible.
also looking to tradefor b series parts/ motor and i am also looking for a buddy club spec 2 exhaust.
Old Mar 21, 2007 | 11:49 AM
bump
Old Mar 21, 2007 | 03:55 PM
ttt
Old Mar 21, 2007 | 06:26 PM
night bump
Old Mar 25, 2007 | 04:03 PM
i'm willing to let everything go for $1,000 or trade for an ls motor and tranny.
Old Mar 26, 2007 | 08:22 AM
2slow4stock's Avatar
Pictures for down pipeand adapter please.
2000civ
16
Sep 13, 2012 07:15 PM
vtec94civic
Mar 25, 2007 04:03 PM
srv3fender
Apr 11, 2005 09:10 AM
awalk2005
Oct 4, 2004 06:26 PM
kingofkingz
Jun 26, 2004 07:04 PM
