Integra or Si Rear Disc brakes
Old Mar 21, 2007 | 09:20 AM
**DOHC HaTcH**'s Avatar
Default Integra or Si Rear Disc brakes
Someone locally is selling some si rear disc brakes without the ebrake cable for 150.
Can i use my existing e brake cable from my 2000 ex?
is there a difference between the si and the integra rear disc brakes?
thanks in advance.
Old Mar 21, 2007 | 09:27 AM
instructor74's Avatar
Default Re: Integra or Si Rear Disc brakes (**DOHC HaTcH**)
there is a differance between the rear disc ebrake cable and on that is for drum brakes. I don't know if there is one between thoughs cars. check magestic honda get the part number and cross it to the integra see if they are the same
Old Mar 21, 2007 | 09:28 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
the only difference will be that the ek brake cables will be longer then the integra units.
Old Mar 21, 2007 | 09:32 AM
Chim Chim's Avatar
All rear discs are essentially the same... You need a ebrake cable from a EM1 for a perfect fit. All of this info can be found in the brake swap thread.
https://honda-tech.com/zerothread?id=1811368
Old Mar 21, 2007 | 09:49 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Integra or Si Rear Disc brakes (Chim Chim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chim Chim &raquo;</TD></TR><TR><TD CLASS="quote">All rear discs are essentially the same... You need a ebrake cable from a EM1 for a perfect fit. All of this info can be found in the brake swap thread.
https://honda-tech.com/zerothread?id=1811368</TD></TR></TABLE>
I shoehorned in GSR cables on my 99 hatchbox when i did a 5 lug because i allready possessed said cables. I Had to bend/omit brackets, and almost completely extend the ebrake screw adjuster. But they fit and worked fine. The 99-00 Si cables will work much nicer with no shoe horning needed.
Old Mar 21, 2007 | 09:52 AM
Chim Chim's Avatar
Default Re: Integra or Si Rear Disc brakes (B serious)
That's why I said to use EM1 cables for a "perfect fit".
Old Mar 21, 2007 | 10:57 AM
-Gary-'s Avatar
x2
Old Mar 21, 2007 | 12:48 PM
B serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chim Chim &raquo;</TD></TR><TR><TD CLASS="quote">That's why I said to use EM1 cables for a "perfect fit". </TD></TR></TABLE>
yeah i think i meant to quote something else.
whyS0serious
12
Jan 23, 2010 09:51 AM
trip-doh
12
Jan 19, 2008 10:19 AM
tekstyle
Dec 10, 2007 01:40 AM
JLEK
17
Jun 11, 2007 09:58 PM
rhdcivic05
Oct 1, 2006 12:26 PM
