wideband good for NA
Just wondering if a wideband is a wise investment for a NA setup? I mostly see them in boosted applications so i was just curiouse, it seems like it would be a worth while purchase
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david@didrace.com »</TD></TR><TR><TD CLASS="quote">If you know what you're looking at, yes.</TD></TR></TABLE>
I would imagine there is a lot of truth to that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirations »</TD></TR><TR><TD CLASS="quote">LC-1 with XD-16 here works very good.</TD></TR></TABLE>
How about the AEm EUGO
the Innovate, AEM and PLX setups work very well.
I have a PLX-M300 and I've no issues at all. I run it full time on N/A setup.
It's manditory if you're going to tune, all though not really worth it if you're not going to tune.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">the Innovate, AEM and PLX setups work very well.
It's manditory if you're going to tune, all though not really worth it if you're not going to tune.</TD></TR></TABLE>
I am planning on getting tuned, just wating on the head to get back from portflow. So your saying mandatory huh?
Absolutely, an Innovate LM-1 with an LMA-3 is your ticket. I imporved my set up significantly, and is cost effective. I am a dealer, and also local to you. PM me for details, and I'll get you excellent prices.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 »</TD></TR><TR><TD CLASS="quote">
I am planning on getting tuned, just wating on the head to get back from portflow. So your saying mandatory huh?</TD></TR></TABLE>
there is no good way to tune without a wideband.
Please don't confuse what I said to mean that if you have your car tuned you have to have a wideband in there all the time... you can have the car tuned with a wideband and drop back to your normal narrowband after.
Please don't confuse what I said to mean that if you have your car tuned you have to have a wideband in there all the time... you can have the car tuned with a wideband and drop back to your normal narrowband after.</TD></TR></TABLE>
Gotcha
Gotcha
I was using the PLX-R500 and i had issues with their display screen going blank when the display gets hot. It happened on my friends car too. Over here weather is hot and when run them in race car without aircond it goes blank out in a short while.
Thinking of buying another cheaper wideband. Anyone had the PLX M-300 with ZERO problems???
Thinking of these M-300 cause it has a bigger number in very visible red and price i believe just below $300??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris2000 »</TD></TR><TR><TD CLASS="quote">I was using the PLX-R500 and i had issues with their display screen going blank when the display gets hot. It happened on my friends car too. Over here weather is hot and when run them in race car without aircond it goes blank out in a short while.
Yes. M-300 has short wires which limits to mounting location. Hard to find a mounting location as unit is bulky. Pretty damn accurate. Having issues with crome pro datalogging the a/f ratios as it seems plx is not accepted very well.
Otherwise I do like my plx m300 because it has helped me through the process but if I could I would most likely get something different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris2000 »</TD></TR><TR><TD CLASS="quote">Thinking of buying another cheaper wideband. Anyone had the PLX M-300 with ZERO problems???
M300 here, had it over a year, zero problems. I also use basically the M250 setup, I picked up the gauge seperatly and connected it to the output.
IMO the M300's display is pointless, when you're tuning the numbers jump around so much that you can't really follow it anyway. the gauge has the digital display in the center and the analog LEDs around the outside that make it easier to see sudden spikes.
If you're datalogging, once you get the offset(if there is any) you really don't care what the display says anyway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sauceja »</TD></TR><TR><TD CLASS="quote">Yes. M-300 has short wires which limits to mounting location. Hard to find a mounting location as unit is bulky. Pretty damn accurate. Having issues with crome pro datalogging the a/f ratios as it seems plx is not accepted very well.
Otherwise I do like my plx m300 because it has helped me through the process but if I could I would most likely get something different.</TD></TR></TABLE>
what problems are you having with the M300 and Crome? That's what I use and I've never had any problems. (JS
LX Devices for O2 setting)
RacerSi
Dec 30, 2003 12:57 PM
