dohc/sohc engine and gear box
Old Mar 21, 2007 | 06:40 AM
Iccy's Avatar
Default dohc/sohc engine and gear box
Hi,
I am new to this forum. I am still getting used to it so pls forgive me if I make any mistakes.
I drive a 91 Honda ballade 150, carb, 16v sohc.
All I have done so far is put on some 15s and a 40mm drop spring set.
The pic is without the springs.
I am hoping to find out if I am able to put a dohc engine in on my current gear box.
I have the work shop manual and it seems that both engines have the same gearbox?
Can anyone pls advice?
thanks
Old Mar 21, 2007 | 06:54 AM
jlicrx's Avatar
Default Re: dohc/sohc engine and gear box (Iccy)
the DOHC ZC, D16A8, D16A9, D16Z5 engines all use the same transmission as your SOHC engine - since your car is carbed, you will have some fuel system issues to deal with when swapping to a fuel injected DOHC engine, as well as some wiring issues - it would be simpler to run carbs on the DOHC engine
Old Mar 21, 2007 | 07:03 AM
Iccy's Avatar
Default Re: dohc/sohc engine and gear box (jlicrx)
thanks for the reply and info
I am planing to install a Gotech ecu and installing senors much later on....
I am hoping my carb intake manifold will fit on the ZC head but i am unsure of that...
If it wont fit I think I will get one made and put on webers as this will be cheeper and quicker then installing FI.
I do have a much older ZC top end almost compleate but the flanges dont match with any other Honda head I have seen.
89efDUSTY's Avatar
dont forget d16a1
Old Mar 21, 2007 | 07:07 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Iccy &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the reply and info
</TD></TR></TABLE>the DOHC ZC intake manifold is completely different from the SOHC manifolds - we use a TWM intake manifold with the Weber DCOE carbs
[IMG][/IMG]
Old Mar 21, 2007 | 07:10 AM
jlicrx's Avatar
with the carbs, you don't need the ECU or any sensors - we just run MSD 8979 for controlling the ignition timing
Old Mar 21, 2007 | 07:20 AM
SIred91's Avatar
Rainman
Thats sexy.
Old Mar 21, 2007 | 07:23 AM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">the DOHC ZC intake manifold is completely different from the SOHC manifolds - we use a TWM intake manifold with the Weber DCOE carbs
[IMG][/IMG]</TD></TR></TABLE> yah IM manifolds on DOHC are always different...d16a1 IM to d16a6 = hahaha
Old Mar 21, 2007 | 09:36 AM
Iccy's Avatar
ok cool thanks
now I just have to look at getting this engine....
Old Mar 21, 2007 | 10:58 AM
wiZCo's Avatar
Stouts 'n' Scotch
I think I'm going to save this to show to anybody on here that says the DOHC ZC is not a buildable or worthwhile engine. Great setup jlicrx.
Old Mar 31, 2007 | 10:54 PM
Iccy's Avatar
Looks like I am taking this route. I am swoping my turbo for 2 x 40mm side draft webers.
Do I need a high pressure fuel pump for them?
As for the intake manifold I would have to get one made here...
What kind of power can I expect?
Old Apr 12, 2007 | 11:32 AM
Iccy's Avatar
no reply...
anyway got me a set of webers today.. swoped them for my turbo.
in need of a clean..
I will be getthing the dohc engine soon.
and then the intake manifold...
I will be getting a 3-5 psi fuel pump.
any more advice?
Old Apr 12, 2007 | 11:34 AM
wiZCo's Avatar
Stouts 'n' Scotch
Iccy, if you want jlicrx's advice (he's great with ZCs), I suggest signing up at http://www.thezcr.com, he's over there more than H-T it seems. Also, his website: http://www.zcspeed.com.
Modified by wiZCo at 3:33 PM 4/12/2007
Old Apr 12, 2007 | 12:22 PM
Iccy's Avatar
Default Re: dohc/sohc engine and gear box (wiZCo)
thanks!!
sites are cool
permaisuri
Oct 8, 2006 01:35 PM
1_slow_crx
Jun 8, 2006 10:09 PM
DarknessInside51
14
May 30, 2004 12:32 PM
90da
Jul 30, 2003 08:59 AM
$N@kE
May 27, 2003 12:20 PM
