WTF: EG clutch pedal gets stuck on the floor
Old Mar 21, 2007 | 06:08 AM
-HONDA-'s Avatar
Default WTF: EG clutch pedal gets stuck on the floor
okay so i went too start my EG HB(B16) and i press on the clutch pedal and bam! it gets stuck at the bottom feels like theres no clutch lol.... i pop the hood and i see all the clutch fluid leaking little drops from the slave cylinder from the nut closest too the headers? its leaking it really fast! so fill it up and bleed it and then it works great i drove it for 10 min then parked it and it leaked it all out again through the same spot WTF!!! do i need a new slave cylinder? LMK
Old Mar 21, 2007 | 06:09 AM
Ricey McRicerton's Avatar
Default Re: WTF: EG clutch pedal gets stuck on the floor (-HONDA-)
That would make sense....
The damn thing is leaking fluid and killing all your clutch pressure.
Luserkid's Avatar
Try tightening the screw but you probably need a new slave cylinder.
Old Mar 21, 2007 | 06:26 AM
d357r0y's Avatar
Default Re: WTF: EG clutch pedal gets stuck on the floor (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Try tightening the screw but you probably need a new slave cylinder. </TD></TR></TABLE>
Agreed (lucky you, it's cheap & easy!)
Old Mar 21, 2007 | 06:42 AM
usdmEHboy's Avatar
Default Re: WTF: EG clutch pedal gets stuck on the floor (d357r0y)
Same thing happened to me...slave cylinder for sure
Old Mar 21, 2007 | 07:03 AM
DaveSi677's Avatar
Default Re: WTF: EG clutch pedal gets stuck on the floor (Ricey McRicerton)
haha happened to me once its the slave cylinder!
Old Mar 21, 2007 | 07:55 AM
-HONDA-'s Avatar
munchos gracias you guys lol... how much you think they are?
Old Mar 21, 2007 | 08:11 AM
philosofy1's Avatar
Default Re: (-HONDA-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -HONDA- &raquo;</TD></TR><TR><TD CLASS="quote">munchos gracias you guys lol... how much you think they are?</TD></TR></TABLE>
http://www.thehondapartsstore....ch=no
this is just to get an idea, atleast from the dealer.
Old Mar 21, 2007 | 09:10 AM
92ehatch's Avatar
Default Re: (philosofy1)
at advance they are like 30 bucks.
i got one and it works fine.
Old Mar 21, 2007 | 09:12 AM
tpr's Avatar
tpr
BTW replace the clutch master cylinder at the same time. They work together so the same number of cycles are on both. If one has failed the other is not far behind.
Old Mar 21, 2007 | 09:16 AM
xiong651's Avatar
^^^yeap, i just got my two done.
if you fix one, you mine as well do the other too
Old Mar 21, 2007 | 11:04 AM
-HONDA-'s Avatar
how much is a clutch master cylinder?
Old Mar 21, 2007 | 11:25 AM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -HONDA- &raquo;</TD></TR><TR><TD CLASS="quote">how much is a clutch master cylinder?</TD></TR></TABLE>
You might try calling a parts store or a Honda dealership.
Just a thought.
Old Mar 21, 2007 | 12:11 PM
hifonics's Avatar
Default Re: (Eran)
mine leaks too but i have'nt had the time too replace it
wardseg6
Feb 15, 2007 01:42 PM
TheAccordGuy
Nov 9, 2006 04:41 PM
707EF8
Jul 29, 2006 08:32 PM
bsixteen
Apr 17, 2005 04:06 PM
Jowee
Feb 12, 2003 12:25 PM
