WTF: EG clutch pedal gets stuck on the floor
Old 03-21-2007, 06:08 AM
-HONDA-'s Avatar
Default WTF: EG clutch pedal gets stuck on the floor
okay so i went too start my EG HB(B16) and i press on the clutch pedal and bam! it gets stuck at the bottom feels like theres no clutch lol.... i pop the hood and i see all the clutch fluid leaking little drops from the slave cylinder from the nut closest too the headers? its leaking it really fast! so fill it up and bleed it and then it works great i drove it for 10 min then parked it and it leaked it all out again through the same spot WTF!!! do i need a new slave cylinder? LMK
Old 03-21-2007, 06:09 AM
Ricey McRicerton's Avatar
Default Re: WTF: EG clutch pedal gets stuck on the floor (-HONDA-)
That would make sense....
The damn thing is leaking fluid and killing all your clutch pressure.
Luserkid's Avatar
Try tightening the screw but you probably need a new slave cylinder.
Old 03-21-2007, 06:26 AM
d357r0y's Avatar
Default Re: WTF: EG clutch pedal gets stuck on the floor (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Try tightening the screw but you probably need a new slave cylinder. </TD></TR></TABLE>
Agreed (lucky you, it's cheap & easy!)
Old 03-21-2007, 06:42 AM
usdmEHboy's Avatar
Default Re: WTF: EG clutch pedal gets stuck on the floor (d357r0y)
Same thing happened to me...slave cylinder for sure
Old 03-21-2007, 07:03 AM
DaveSi677's Avatar
Default Re: WTF: EG clutch pedal gets stuck on the floor (Ricey McRicerton)
haha happened to me once its the slave cylinder!
Old 03-21-2007, 07:55 AM
-HONDA-'s Avatar
munchos gracias you guys lol... how much you think they are?
Old 03-21-2007, 08:11 AM
philosofy1's Avatar
Default Re: (-HONDA-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -HONDA- &raquo;</TD></TR><TR><TD CLASS="quote">munchos gracias you guys lol... how much you think they are?</TD></TR></TABLE>
http://www.thehondapartsstore....ch=no
this is just to get an idea, atleast from the dealer.
Old 03-21-2007, 09:10 AM
92ehatch's Avatar
Default Re: (philosofy1)
at advance they are like 30 bucks.
i got one and it works fine.
Old 03-21-2007, 09:12 AM
tpr
tpr's Avatar
BTW replace the clutch master cylinder at the same time. They work together so the same number of cycles are on both. If one has failed the other is not far behind.
Old 03-21-2007, 09:16 AM
xiong651's Avatar
^^^yeap, i just got my two done.
if you fix one, you mine as well do the other too
Old 03-21-2007, 11:04 AM
-HONDA-'s Avatar
how much is a clutch master cylinder?
Old 03-21-2007, 11:25 AM
HT White Ops
Eran's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -HONDA- &raquo;</TD></TR><TR><TD CLASS="quote">how much is a clutch master cylinder?</TD></TR></TABLE>
You might try calling a parts store or a Honda dealership.
Just a thought.
Old 03-21-2007, 12:11 PM
hifonics's Avatar
Default Re: (Eran)
mine leaks too but i have'nt had the time too replace it
wardseg6
02-15-2007 01:42 PM
TheAccordGuy
11-09-2006 04:41 PM
707EF8
07-29-2006 08:32 PM
bsixteen
04-17-2005 04:06 PM
Jowee
02-12-2003 12:25 PM
Quick Reply: WTF: EG clutch pedal gets stuck on the floor
