d17 oil pump on a built z6? boost'n
im building a z6 n i m gonig 2 order a new oil pump, will the d17 oil pump give me added advantages over the stock z6 one?
i have a y8 built head, do i order a y8 timing belt, water pump, tensioner, bold n spring 4 the y8 or the z6?
4 about 450hp will new oem piston rings hold on je pistons?
Modified by Swipe'd at 10:50 AM 3/22/2007
Its unlikely... there doesnt seem to be anything about it (or anything else in that motor) that makes it any better than any of the other ones, but I have one here that I messed up the mating surface on trying to pry it off the block, so its useless, but if you want it for R&D, IM me...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Swipe’d »</TD></TR><TR><TD CLASS="quote">im building a z6 n i m gonig 2 order a new oil pump, will the d17 oil pump give me added advantages over the stock z6 one? just use the stock z6 one, it works great.
i have a y8 built head, do i order a y8 timing belt, water pump, tensioner, bold n spring 4 the y8 or the z6? use the parts according to which motor the part is from, and use a timing belt from the head that you have.
4 about 450hp will new oem piston rings hold on je pistons? likely, ive seen 375 even on stock pistons. but how do you plan on getting 450hp on a z6?</TD></TR></TABLE>
94EG8
10
Jan 19, 2014 02:29 PM
jdmf23accord
14
Dec 3, 2010 06:09 PM
