H22 compression, really low. Blowing smoke, say goodbye?
Old Mar 20, 2007 | 09:33 PM
squarepusher's Avatar
Default H22 compression, really low. Blowing smoke, say goodbye?
so i got a car for a pretty good deal 'non running' and then i was trying to get it fixed. its an h22a in a 96 civic.
it stalls out and the blows some whitish smoke with some black particles liek its burning oil/fuel too.
the compression ran at around 130 across, i am going to the shop tommorrow to talk with the dudes, but they said i should be thinking about a new h22 swap (for $1500 installed they say)
is this agreeable to you all? they say the piston rings/seals are probably shot, this is (was) a build engine. suggestions? not sure i wanna get an entire new swap, this car already caused me a a big headache.
Old Mar 20, 2007 | 09:39 PM
prelude_h22vtec's Avatar
pull the head, survey the damage. it could just be the head gasket, maybe just rings. replacing those could cost $1000, so you could be better off just replacing it for 1500.
Old Mar 20, 2007 | 10:03 PM
Default Re: (prelude_h22vtec)
damn, i guess a new h22 is coming my way then =[ it could be worst, 1500 is not that bad.
would you all recommend JDM or USDM? also any dealers who you would buy a engine from? thx
Old Mar 21, 2007 | 07:05 AM
jdmlude5
Guest
Posts: n/a
Default Re: (squarepusher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by squarepusher &raquo;</TD></TR><TR><TD CLASS="quote">damn, i guess a new h22 is coming my way then =[ it could be worst, 1500 is not that bad.
would you all recommend JDM or USDM? also any dealers who you would buy a engine from? thx</TD></TR></TABLE>
jdm morecompression
Old Mar 21, 2007 | 07:44 AM
alterdcreations's Avatar
Default Re: (jdmlude5)
sell me your old engine
Old Mar 21, 2007 | 08:05 AM
prelude1897's Avatar
Default Re: H22 compression, really low. Blowing smoke, say goodbye? (squarepusher)
Sounds like you need some new valves....You could just buy a whole different motor for about that price or even cheaper and drop it in...
Old Mar 21, 2007 | 08:08 AM
Default Re: (alterdcreations)
hey altered creations.
let me give you some more info on the engine before you want to get involved.
its a h22 bored to 2.4l with eagle rod pistons with 12.5:1 ratio, ran on pump gas still. it was running fin, then now it has really bad compression (between 120-130) so im prol gunna do a stock h22 like i said, and ill pretty much take any offer for the old one. do you want intake and header too or just the engine?
better talk to me direct cmorera2(at)yahoo.com
Specail Ed
Mar 10, 2009 12:39 PM
squarepusher
Jun 14, 2007 04:03 PM
Yuleluder
May 23, 2006 06:23 PM
nickwilmot
Oct 10, 2003 09:42 PM
spiderz
May 28, 2003 01:03 AM
