Honda S2000 Honda S2000
AEM EMS
Old Mar 20, 2007 | 09:10 PM
cheese steak Nazi's Avatar
Default AEM EMS
OK ....Im looking to get this but which one do i need ..
These are the 2 i found :
00-04 S2000...M/T only (haha guess they dont know it doesnt come in auto)
00-04 S2000...M/T only W/UEGO
Whats UEGO?
Heres the LINK http://www.importevolution.com...72_73
i have 00 s2k
Old Mar 20, 2007 | 11:25 PM
96-EJ6 B18C's Avatar
Default Re: AEM EMS (Cheese Steak ****)
UEGO=Universal Exhaust Gas Oxygen sensor, basically the AEM box has a wideband o2 sensor controller included in the box, if you have or are planning on getting a separate wideband o2 the option is unnecessary.
Personally, I would check out the new Hondata K-Pro for the S2000. Many people in this forum will not agree with me, but the Hondata will leave you with a much better running car.
Old Mar 21, 2007 | 12:30 AM
Thanks i will have to look into that k-pro too....
Now with the AEM EMS i take it ill need the one W/UEGO..?
Old Mar 21, 2007 | 04:34 AM
papa5murf's Avatar
Model numbers.
1052 = no UEGO
1052U = with UEGO
Keep in mind the AEM EMS is not OBDII compatible.
As for the hondata, I'd pass, it's way overpriced, and you have to change a lot of sensors. So it's not a plug in and go, and not easy to go back to stock if need be. (cause you'll have to change your sensors back). I'd much rather pick up an HKS F-con. (but you have to find a tuner, which is hard if you're not in the right place)
Old Mar 21, 2007 | 04:38 AM
revhi's Avatar
What was the 1012?
Old Mar 21, 2007 | 05:16 AM
papa5murf's Avatar
Default Re: (revhi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhi &raquo;</TD></TR><TR><TD CLASS="quote">What was the 1012?</TD></TR></TABLE>
That was the first one that had some issues I believe. There's still some of those floating around.
Old Mar 21, 2007 | 06:02 AM
Francesco's Avatar
Default Re: (papa5murf)
you want 1052u.
Built in wide band with that model
Old Mar 21, 2007 | 06:43 AM
papa5murf's Avatar
Default Re: (Francesco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">you want 1052u.
Built in wide band with that model </TD></TR></TABLE>
I'll sell you mine, if I can find a "good" tuner for the HKS F-con V Pro.
Old Mar 21, 2007 | 07:38 AM
accordianex's Avatar
Default Re: (revhi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">Model numbers.
Does this mean that you would not be able to plug in an OBDII scanner?
how would one pass inspection with an AEM EMS installed?
Old Mar 21, 2007 | 07:46 AM
RacerXI's Avatar
Default Re: (accordianex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordianex &raquo;</TD></TR><TR><TD CLASS="quote">
You'll need to swap back in your stock ecu, get a "hookup", or something along those lines.
Old Mar 21, 2007 | 07:50 AM
papa5murf's Avatar
1. Not compatible with an OBDII scanner.
2. Depending on the state you live in, most states, you can't pass emissions with an AEM EMS. You'll need connections or put your OEM ECU back in for the short period. I believe it needs to go through 3 full cycles (fully warmed up, and fully cooled) to register on the scanner.
Old Mar 21, 2007 | 08:42 AM
mportracer33's Avatar
or just do what every other turbo honda guy does...pay someone to pass it for you
Old Mar 21, 2007 | 01:43 PM
Default Re: (mportracer33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mportracer33 &raquo;</TD></TR><TR><TD CLASS="quote">or just do what every other turbo honda guy does...pay someone to pass it for you</TD></TR></TABLE>
Cant do that with an OBDII in NY
Old Mar 21, 2007 | 10:57 PM
i did it everytime with my integra. 650 whp integra daily driven gotta know the right people. if you got someone on the inside, its cake
Old Mar 22, 2007 | 01:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mportracer33 &raquo;</TD></TR><TR><TD CLASS="quote">i did it everytime with my integra. 650 whp integra daily driven gotta know the right people. if you got someone on the inside, its cake</TD></TR></TABLE>
yes about 2 years ago you could do this, now they scan your vin and hook a computer up to your ECU. Without steeling a sticker i dont see how someone could do this anymore in NY.
Old Mar 22, 2007 | 11:17 AM
damn that sucks...still easy here in maryland
Old Mar 22, 2007 | 08:49 PM
Francesco's Avatar
I'll sell you mine, if I can find a "good" tuner for the HKS F-con V Pro.</TD></TR></TABLE>
PM me, im interested if its new in the box
Why are you not using AEM though for the turbo? Im not a fan of the HKS.
Old Mar 22, 2007 | 08:59 PM
LAS2K's Avatar
HKS f-con pro has 128 points of tuning on the chart correct? while aem has 24?
Old Mar 23, 2007 | 04:50 AM
papa5murf's Avatar
Why are you not using AEM though for the turbo? Im not a fan of the HKS.</TD></TR></TABLE>
I'm using the AEM EMS for the sole reason that there are tuners all over the place. I would take the HKS F-con V pro or the Apex-i Power FC over the AEM EMS in a heartbeat if I could find a good local tuner.
HKS = 32x32
Apexi = 20x20
AEM = 16x16
The F-con and Power FC have absolutely no issues with start up/cold starts. They also run a lot smoother then the EMS.
Old Mar 23, 2007 | 10:23 AM
Mr. Projekt's Avatar
* B A N N E D *
HKS F-Con AND there's a tuner here in the West Coast.
Old Mar 23, 2007 | 10:53 AM
papa5murf's Avatar
Default Re: (Mr. Projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">HKS F-Con AND there's a tuner here in the West Coast. </TD></TR></TABLE>
Yeah, I know, but I'm on the wrong coast.
There is a shop in MD that is a dealer of HKS, but I dunno if I trust them to tune. LOL maybe after I get the EMS tuned and they can copy the plots over and then fine tune from that.
Old Mar 26, 2007 | 09:13 PM
you talkin about altered atmosphere?
Old Mar 27, 2007 | 04:01 AM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mportracer33 &raquo;</TD></TR><TR><TD CLASS="quote">you talkin about altered atmosphere?</TD></TR></TABLE>
Yep, they seem to be the closest. Don't know much about them though. The next closest would be up in New York or PA.
Old Mar 27, 2007 | 05:25 AM
BlueSi2k's Avatar
yes about 2 years ago you could do this, now they scan your vin and hook a computer up to your ECU. Without steeling a sticker i dont see how someone could do this anymore in NY.</TD></TR></TABLE>
I passed in ny . I was working on a little ecu simulator that hooks up to the obd plug wires. I have a working prototype and will most likely have a couple made in the up coming months. Of course it should only be used for "testing of scan tools" . The VIN needs to be hard coded in the firmware as the tester requests the vin from the ECU.
Old Mar 27, 2007 | 02:25 PM
Sarek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
F-Con tuner in the West Coast? where? I'm in Northridge, CA... I was looking into getting the AEM EMS 1052u too.
btw, i'm intersested in your center console but can't post on that thread
Modified by Sarek at 3:52 PM 3/27/2007
