Please help over heating VERY BAD!
Old Mar 20, 2007 | 09:03 PM
CivicGSRsi's Avatar
Default Please help over heating VERY BAD!
I have a 99si coupe with a gsr swap i was drivin home and it looked like some one dumped a buckit of water on my windsheild so i stoped b/c i new it was my coolint and after it stoped smokin after the coolint burnt all up i started driving home and it was crazy over heating i ges my ? is why would my coolint explode like it did out from under my hood i was not driving hard at all so after my dump *** drove home any how i ges from it being so hot the radeater has a crack in it "sorry for my spellin"
Old Mar 20, 2007 | 09:04 PM
novtecnoboost's Avatar
Default Re: Please help over heating VERY BAD! (CivicGSRsi)
maybe ur thermostat is stuck or u poped a hose
Old Mar 20, 2007 | 09:07 PM
CivicGSRsi's Avatar
Default Re: Please help over heating VERY BAD! (theb18c1)
Well if my thermostat is stuck can u make it unstuck with out buyin a new one?
Old Mar 20, 2007 | 09:15 PM
JDM_Frijoles's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicGSRsi &raquo;</TD></TR><TR><TD CLASS="quote">Well if my thermostat is stuck can u make it unstuck with out buyin a new one?</TD></TR></TABLE> They're under 20 bucks?!
Old Mar 20, 2007 | 09:39 PM
highrev1987's Avatar
Default Re: Please help over heating VERY BAD! (JDM_Frijoles)
you definatly popped a hose, how would a thermostat sticking dump coolant on the windshield????
Old Mar 20, 2007 | 09:46 PM
Default Re: Please help over heating VERY BAD! (highrev1987)
so if he changes the poped hose and doesnt check the thermostat
wouldnt the stuck thermo just pop it again cause its not letting the water cyclee threw.
yaeh changing the thermo is a 10 minute job
and its very cheap
Old Mar 20, 2007 | 11:46 PM
smileycvc's Avatar
Hope you didnt warp the head or anything overheating the motor.
Old Mar 21, 2007 | 06:57 AM
CivicGSRsi's Avatar
Default Re: Please help over heating VERY BAD! (smileycvc)
Were is the thermostat at !
Old Mar 21, 2007 | 09:15 AM
92ehatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicGSRsi &raquo;</TD></TR><TR><TD CLASS="quote">Were is the thermostat at !</TD></TR></TABLE>
its on the block near the passenger side. near the distributor, it has a hose running to it (obviosly) this is the lower radiator hose.
there are a couple grounds on it.
its like 2 bolts to undo, then pop out the thermostat, PAY ATTENTION TO HOW IT COMES OUT.
put new one in. bolt up bolts. fill/bleed coolant.
Old Mar 21, 2007 | 09:24 AM
instructor74's Avatar
Default Re: Please help over heating VERY BAD! (92ehatch)
please use the spell check button(its next to the ? above the text box it has ABC with a check mark under it) before you post and proof read. Make sure what you are posting makes sense. I know that we can guess what you are trying to get across but it is a lot easier not to have to.
invisible
Mar 20, 2007 07:43 PM
snowblind7x
Feb 21, 2007 08:58 PM
importfanatic17
Jan 4, 2007 09:14 PM
rogue420
20
Jun 8, 2005 07:50 AM
BoostNEF
May 14, 2005 01:18 AM
