B16a build up with out pulling out the hole engine. need some help???
Old Mar 20, 2007 | 08:51 PM
MHBb16CRX's Avatar
Default B16a build up with out pulling out the hole engine. need some help???
I want to gain the most hp out of my engine with out building up the block. What can I do to my head without Blowing my engine. Whats the most hp I can gain? I will be builing up the block later. But not now.
I have now:
DC 4-2-1 header
2.5 pipe
short ram
stage 2 clush
I was thinking to go with:
stage 2 cams & valves (or is this to much for a stuck the block?)
Edelbrock Performer X Intake
Edelbrock Fuel rail
Edelbrock 75mm TB ( I heard that a mustang TB will work?)
ligh fly wheel
Vtec Controller
chip???
what Do you guys think?
Thanks
Old Mar 20, 2007 | 09:16 PM
garageEF's Avatar
Default Re: B16a build up with out pulling out the hole engine. need some help??? (MHBb16CRX)
type R valvetrain
type R TB
light wieght flywheel
are you obd0 or obd1?
chip your ecu and have it tuned.
youll haul ***!!
Old Mar 20, 2007 | 09:58 PM
.Manny.'s Avatar
Touching My Member
Default Re: B16a build up with out pulling out the hole engine. need some help??? (garageEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garageEF &raquo;</TD></TR><TR><TD CLASS="quote">type R valvetrain
type R TB
youll haul ***!!</TD></TR></TABLE>
not with that you wont.
a b16 with stiffer springs, a chip and a bigger throttle body wont make that much of a difference.
if you want a header, dont go DC, they suck ***. a 75mm TB will probably hinder performance.
bigger cams
2.25" should be enough
hi-flow cat
stock fuel rail
vtec controller
aftermarket valvetrain
doing lots of research before doing anything
Old Mar 21, 2007 | 06:48 AM
MHBb16CRX's Avatar
well the DC header came with the engine. are Stage 2 cams safe with a stuck block? & what brand should I buy?
Old Mar 21, 2007 | 09:27 AM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MHBb16CRX &raquo;</TD></TR><TR><TD CLASS="quote">
DC 4-2-1 header - Ditch this header
2.5 pipe
short ram
stage 2 clush
stage 2 cams & valves (or is this to much for a stuck the block?) - There is no universal "stage 2" cam...it depends on the company, and also depends on your displacement and CR
Edelbrock Fuel rail
Edelbrock 75mm TB That huge of a TB will hinder performance like a couple other guys said
ligh fly wheel
Vtec Controller both of these next items are pointless, blind, bandaids...get it tuned.
chip???
Thanks
It really sounds like you should do some more reasearch on the builds on honda-tech. Like i said, there is no universal stage 2 cam, and there isn't just 1 brand that makes horsepower. The fact that you asked us what you can do to your head without "blowing" the motor shows us that you need to do a little more research, or at least get a good engine builder on your side.
Old Mar 21, 2007 | 09:56 AM
MHBb16CRX's Avatar
Default Re: B16a build up with out pulling out the hole engine. need some help??? (gibsanez)
What kinda of cams, valve springs, retainers, and valves should I buy?
Thanks
Old Mar 21, 2007 | 11:46 AM
gibsanez's Avatar
I've heard good things about the rocket motorsports lineup, like the m22x cams and matching valvetrain. Do you plan on going with a higher compression ratio later on? Skunk2 makes a decent cam too, just do some searching through the all-motor forums, they're riddled with "my build" threads.
Old Mar 21, 2007 | 11:58 AM
MHBb16CRX's Avatar
well I want to build the head now then I'll go trubo with very low bost (around 6 psi), then I'll build the block to hold up about 20 psi bost. But now I'll build the head + some bolt ons within a month. thanks
Old Mar 21, 2007 | 12:09 PM
HOODLOVER's Avatar
how come the vtec controller got the thumbs down?
Old Mar 21, 2007 | 01:04 PM
CRX Toad's Avatar
Default Re: B16a build up with out pulling out the hole engine. need some help??? (HOODLOVER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOODLOVER &raquo;</TD></TR><TR><TD CLASS="quote">how come the vtec controller got the thumbs down?</TD></TR></TABLE>
Because a chipped ECU should do the job better.
battmancjz
Jan 23, 2012 11:47 AM
MHBb16CRX
13
Mar 21, 2007 09:52 AM
yellowEG
12
Mar 19, 2005 02:58 PM
93lsd
Jun 20, 2004 08:41 PM
bossman032
Jun 13, 2003 07:11 PM
