B18 stall and idle low, shuts off.
Well, I have a b18a turbo and starting in the cold, it idle very low like 500-600 rpm, isn't it suppose to idle high around 2000 rpm? It'll stall and felt like it's not getting gas, even though it gets to normal operating temperature. It still idle 500-600. It something just shuts off and die. Today when I went to start it up in the morning, the car would just crank and wouldn't start unless you give it some gas. Once it does, unless you hold the gas pedal, the rpm will drop and shut off. I try adjusting the idle screw. I just did a oil change with 20-50 vr1 motor oil couple days ago. What could the problem be???
Modified by Tenji at 1:37 PM 3/21/2007
