Help removing stock rear sway bar '00 Civic SI
Old Mar 20, 2007 | 08:19 PM
MonkeyPuzzle's Avatar
Default Help removing stock rear sway bar '00 Civic SI
I am attempting to remove the stock SI rear sway bar and have run into a bit of a problem.
The bolt that goes through the rear LCA just turns and turns, doesnt get looser or tighter.
How do I hold the bolt solid so I can remove the nut?
I will continue to search through H-T's archive but I need help asap. Please help.
Old Mar 20, 2007 | 08:27 PM
Default Re: Help removing stock rear sway bar '00 Civic SI (MonkeyPuzzle)
Small clarification, I'm actually having trouble removing the endlinks, dont know if that was clear in my description.
I need to remove the nut from the bold that holds the end links for the sway bar to the rear LCAs.
Old Mar 20, 2007 | 08:32 PM
pdiggitydogg's Avatar
The stud has an allen key hole in it (think i told you this before) - put an allen in the hole, hold it, turn the nut
If this allen hole is stripped/rounded....youre kinda screwed and will have to cut it off
Old Mar 20, 2007 | 08:36 PM
Default Re: (pdiggitydogg)
ahh, yes, there is indeed an allen key hole, did not see that, or perhaps remember that.
I know I tried to do this once a year or so ago so I may very well have asked already, thanks very much
(when I read the manual it just says "Remove the nut" not so handy)
Old Mar 20, 2007 | 09:19 PM
Default Re: (MonkeyPuzzle)
yeah, the allen key hole is stripped like crazy wow.
looks like I will have to drill it out... but come to find my drill and all its bits are missing... i suspect borrowed without asking/theft is at fault here
Coolcat55
38
Jun 26, 2008 02:50 PM
MSUGeoman22
May 29, 2008 07:00 PM
yuning83
Honda Civic (2006 - 2015)
17
Aug 17, 2007 04:28 PM
jdmstreethatch
Nov 11, 2004 12:20 PM
Kid1320
84
Mar 12, 2003 07:01 AM
