Name this part
okay well after putting in the new engine im left with these two washers
i noticed my shifter felt very loose moving it side to side in neutral
the quarter shows how big the washers are
Yo those look like the shims that are inside the bell housing on the tranny. I remember this because when Bense put together my with the LSD install we had to match those up so that we would have the proper tollerances. Hit up Bense and show him that, he'll probably agree with me on that one.
Yes.. that piece is for the upper part of the shift linkage. Thats probably why your shifter seems pretty loose. The washer goes in first then the black piece goes on front which covers up the linkage insert. You will need a bolt to screw that piece in to the tranny. Hope this helps. Also check the helms manual, they got helpful diagrams on how to install this piece.
Those are definitley shifter stabalizer washers. You won't even be able to shift if your stabalizer bar falls off. The washer with the big dip goes on the outer edge of thebushing and the other one goes on the inward side. Hopefully you get this before you venture out with the car. Good Luck
is this how it goes?
lol im so confused i went up under the car and neither one will fit in between that rod thing so do they each go on opposite sides with bolt going threw
no, take then and they go on the transmission side.
if you are laying under the car, it will go on the linkage to the left thin one on first, then the linkage, then the cupped one.
hope that helps
hope that helps
picture was taken of me laying head in from drivers side so its on the side of the driver
and so that big one chills by itself? it doesnt go with the cup thing like i have it because then it seems like it sags
Your at the wrong end, those washers go on the tranny end of the bar!
Do yourself a favor and buy a $15 Haynes manual. We have been telling you that it bolts into the tranny, you are at the shifter.
ok what i did was put the flat washer on the transmission part then put the rod thing on followed by hat thing going toward to rod followed by screwing it in. is this right?
i checked my shifter still moved side to side like jelly
would that broken boot below the shifter itself cause that..it seems ript pretty bad
tom91ita
Jan 25, 2005 06:44 PM
hondaracing1
Aug 4, 2004 05:42 PM
