Skunk2 Camber kit
I just bought the Skunk2 camber kit for my 95 civic ex 2 door but it didn't come with any bolts. My questions is can I just use the stock bolts off my car to install this camber kit or will the shop Im taking my car to have to order extra parts to be able to install this?
none of the skunk2 camber kit comes with the bolt. you'll have reuse the stock bolt. don't waste yourmoney at the shop. it's very easy to do. all you need are(i think, not sure) ratchet, 12mm, 14mm, and a pickle fork for the ite-rod. very easy to do.
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kay20adc2 »</TD></TR><TR><TD CLASS="quote">none of the skunk2 camber kit comes with the bolt. you'll have reuse the stock bolt. don't waste yourmoney at the shop. it's very easy to do. all you need are(i think, not sure) ratchet, 12mm, 14mm, and a pickle fork for the ite-rod. very easy to do. </TD></TR></TABLE>
dont use a pickle fork. You will destroy the boot, and eventually the balljoint in there will fail. Use a hammer. Hammer NOT ON THE TIE ROD, but on the cast iron part of the knuckle where it connects. A couple of good hits, and it vibrates loose. DONT HIT THE TIE ROD.
I just installed a set of these. Did use a pickle fork. Did screw up the boots on the stock a arms. Going to toss em anyway. It is easy though, screw paying someone else to do that!
x2 very good brand
x2 very good brand
