brake problems...pls. help
i have an EF civic 91 Si, when im going around 50mph and i hit the brakes even just a little bit. my car shakes everytime. i can feel it shaking from the front idk what's wrong. what should i do?
check it out, see if there is any play in the upper or lower ball joint or the tie rod end, or the radius rod bushings, or the rotors or calipers, or the wheel bearing. do you hear any clunking when going over bumps?
On my right side i hear clicking sounds when i turn, i think its my axle other than that i dont hear anything else. is that causing my car to shake??
Spence
Jul 18, 2005 03:55 PM
Spence
Suspension & Brakes
Jul 18, 2005 03:38 PM
