I Need Advice. Installed a New Header on my DOHC ZC. Hangs Way Too Low...AC Fan Won't Fit.
Old Mar 20, 2007 | 01:24 PM
JesseCRX's Avatar
Default I Need Advice. Installed a New Header on my DOHC ZC. Hangs Way Too Low...AC Fan Won't Fit.
Cliff's Notes:
1. Had a DC Header on my ZC. Had a very bad crack where the welds were made near the head.
2. Bought a D-series Edelbrock Header as a replacement. Box says 92-95 Honda Civic but I was told any D-series header would work fine.
3. Hangs too low - the part where the cat connects to it is hitting when I go over bumps.
4. AC Fan won't fit. Header runners extend outwards and then go down.
What can I do to remedy these problems? I wanna run AC but there's no way my fan is going to fit. Can the header be heated and angled so that it won't hang so low or does it have to be cut and rewelded?
Also my AC hose busted because of the heat from the header....so yeah, the problems just keep building up. I spent money to fix one problem and now I have more problems as a result of it all.
Old Mar 20, 2007 | 02:16 PM
JesseCRX's Avatar
Default Re: I Need Advice. Installed a New Header on my DOHC ZC. Hangs Way Too Low...AC Fan Won't Fit. (Je
any-juan?
Old Mar 20, 2007 | 02:25 PM
JesseCRX's Avatar
Well, another question I have is do I need 2 fans? I know the AC fan is for the AC but will it work just fine without it? Or is it absolutely necessary?
Old Mar 20, 2007 | 04:09 PM
n3h3bkau's Avatar
Curious myself being that I have a Edelbrock Header and will soon be installing my Dohc ZC. With my A6 however it works alright minus the A/C fan removal and a slight notch in my crossmember for clearance.
Perhaps a slim fan?
Old Mar 20, 2007 | 04:29 PM
janz3n's Avatar
Default Re: (n3h3bkau)
iv got an oem dohc zc exhaust manifold on my d15b2 at the moment. its basically a header 4-2-1. my car isnt lowered and i hit it with speed bumps if i go to fast.. so i dont know if you can help this out at all.. unless you cut it and weld it again.
i removed my ac fan .. im not really sure if my other fan is working properly now because i overheated last month.. but a few weeks ago i could hear it was on. but iv heard if you remove the ac fan it doesnt complete a circuit so im not sure.
Old Mar 20, 2007 | 04:46 PM
djphonics's Avatar
Default Re: (janz3n)
I just bought that exact header and have it installed with my DOHC ZC....but I also ripped out all the AC stuff. It fits fine and clears my JimFab crossmember. It hangs a bit low, but I haven't found that it's rediculously low.
Here is a top view (I'll try to remember to get a front view tonight):
Old Mar 20, 2007 | 04:53 PM
janz3n's Avatar
Default Re: (djphonics)
clean zc.. pretty header
Old Mar 20, 2007 | 05:45 PM
JesseCRX's Avatar
Well, they did have to cut they lip off of the OEM crossmember for the header to fit without problems.
I'll take pics of the cars belly tomorrow in the morning and show you guys what I mean.
Right now my car is sitting on Eibach Sportlines with KYB's.
It's not slammed, but not super high either.
Old Mar 20, 2007 | 07:54 PM
my91tealhb's Avatar
Default Re: (JesseCRX)
I bought them same header from summit also. Its a great deal but I was thinking about sending it back. Seems like a lot of work to make it fit. I want to keep my A/C also. Post some pics JesseCRX.
Old Mar 20, 2007 | 10:10 PM
JesseCRX's Avatar
Default Re: (my91tealhb)
Well, I am thinking it's going to take some extra work in the form of:
1. Getting a 92-95 Civic Radiator(dirt cheap on ebay).
2. Getting a slim fan for the AC Condensor(60 bux from a HT vendor)
As for it hanging too low, it may just be the flange from the cat converter....not sure.
I'll get the pics later today when I park the car on level pavement.
Old Mar 20, 2007 | 10:20 PM
djphonics's Avatar
Here's my pics for reference:
Ground clearance pic:
JimFab crossmember clearance pic:
Old Mar 20, 2007 | 11:47 PM
C_I_V_I_C_V_T_E_C's Avatar
i don't have any a/c parts in my car at all. if u got windows i think ull be allright. well unless ur in the desert. and another + is that without the a/c lines it makes it much easier to work on ur car
Old Mar 21, 2007 | 06:57 AM
jlicrx's Avatar
your best bet is to use the 88-91 header - it will fit with the A/C
Old Mar 21, 2007 | 08:56 AM
JesseCRX's Avatar
Default Re: (C_I_V_I_C_V_T_E_C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_I_V_I_C_V_T_E_C &raquo;</TD></TR><TR><TD CLASS="quote">i don't have any a/c parts in my car at all. if u got windows i think ull be allright. well unless ur in the desert. and another + is that without the a/c lines it makes it much easier to work on ur car</TD></TR></TABLE>
I am in Houston TX(aka the devils *******). It gets hot AND humid as expletive down here. AC is a must.
Here are the pics I took before and I after I had some modification done.
Top down view of AC lines touching header(No AC Fan)
Here are some underbelly shots of the header flange/cat converter
And here are some shots after I had the lower heat shield cut and the header heated and slightly bent upward. I was pretty pissed that this had to be done but it was either this or risk seriously ******* some **** up.
It still sits too low for my tastes.
Old Mar 21, 2007 | 09:01 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">your best bet is to use the 88-91 header - it will fit with the A/C</TD></TR></TABLE>
I actually am in the process of re-installing A/C on my 90 with a DOHC ZC. I am going to have to use the stock header so that it 1) works with the stock A/C fan (don't really feel like speding money on a slim fan), 2) Allows the compressor to fit comfortably and 3) gives the lines more room.
Depends on what you'd rather have: an aftermarket header that adds a few HP or ice cold air in the dog days of summer. For me A/C &gt;&gt;&gt;&gt;&gt;&gt;&gt; a few measly HP, especially on a DD.
Old Mar 21, 2007 | 09:12 AM
my91tealhb's Avatar
Jessecrx,
Thanks for the pics! Hangs pretty low & sucks that it touches the A/C lines. I need my A/C here in Cali. You could probably squeeze a slim fan in there though! I think I am going to return the header. Thanks for the heads up!
Old Mar 21, 2007 | 09:28 AM
ChickenH's Avatar
i had a 4 to one dc on my b in my crx and it hung down like that. I think its because it was the GSR one and my b16 has a shorter block. it took me a week to smash it bad enough to restrict flow. i cut a slot in it and bent it back into a tube and welded it shut. then fabricated a 1/4 inch slider plate for it. eventually i just took it off and put a 4 to 2 to one on instead.
Old Mar 21, 2007 | 09:43 AM
JesseCRX's Avatar
Default Re: (ChickenH)
Well, the header swap had to be done because the DC header was breaking into pieces due to age and wear.
This is only temporary.
Got a B-series ready to drop in with a hasport ac bracket
Old Mar 21, 2007 | 11:29 AM
JesseCRX's Avatar
OMFG...now it's overheating!
I tried driving to work and the temp guage started to rise.
All I did was reset my ecu. I know for a fact my fan is kicking on because I watched it yesterday.
My head hurts. I just want someone to hold me, and tell me everything gonna be alright
Old Mar 21, 2007 | 11:37 AM
JG90CRX-Si's Avatar
Jesse, I will hold you my brotha!! Hang in there!!
JG
Old Mar 21, 2007 | 11:43 AM
JesseCRX's Avatar
Default Re: (JG90CRX-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JG90CRX-Si &raquo;</TD></TR><TR><TD CLASS="quote">Jesse, I will hold you my brotha!! Hang in there!!
JG </TD></TR></TABLE>
Thanx Johnny.
Tim is trying to set up the motor swap for sometime next week. Think you can lend your hands to help?
I'll bring beer and orange Crush soda!
Old Mar 23, 2007 | 08:43 AM
JG90CRX-Si's Avatar
Let me know what date and I will see if I can roll out there!
JG
Old Mar 23, 2007 | 09:20 AM
HT Chaplain's Avatar
Loved
have you thought of cut and rewelding? Cut it yourself and have someone weld it. That would solve your ground clearance issue. i dont know about the ac line issue though just cut a .5-1inch off of the down section. You be able to find plent of tig welders in houston
Old Mar 23, 2007 | 01:18 PM
JesseCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplain &raquo;</TD></TR><TR><TD CLASS="quote">have you thought of cut and rewelding? Cut it yourself and have someone weld it. That would solve your ground clearance issue. i dont know about the ac line issue though just cut a .5-1inch off of the down section. You be able to find plent of tig welders in houston</TD></TR></TABLE>
Thought about it, but wouldn't that throw off the flow of the header?
It would have to be cut in 2 places. All 4 runners would have to be cut and shortened. Just look at the old DC CRX 4-1 header. See how the runners almost immediately run downward instead of straight out and then down like the Edelbrock. Then I would have to cut it somewhere on the downpipe to shorten the height so it doesn't hang so low.
CRX DC 4-1 Header
JG Edelbrock 4-2-1 Header for 92-95 Civic
If it won't damage the purpose of the header that much then yeah I can probably do it. I already have it off the car. But if it will then I may just be better off putting back on my old DC 4-1.....which was cut in half by the muffler shop without my knowledge and then rewelded back together
I also noticed that the DC header has some sort of a bracket near the o2 sensor. The Edelbrock one doesn't have this. Is it necessary? What goes there?
Old Mar 23, 2007 | 01:21 PM
JesseCRX's Avatar
CRX DC 4-1 Header
