HELP WILL THIS FIT????
i have a 93 civic EX with the D16Z6 motor and i need to know will a transmission from a 97 civic ex with a D16z6 or it may be a Y8 but i herd they are pretty much the same. but any way will the tranny from that 97 civic fit my 93 civic i also know the interchange parts are 92-95 but is it an exception for the tranny??? they are both a hydrolic clutch set up??? please help
jared
jared
you should be able to swap the tranny without major probs since most d-series parts are interchangable. and the y8 has steel shifter forks as the z6 is aluminum, also i believe that gears are closer on the y8 so it would be a nice upgrade with your z6 motor.
i believe that the clutch will fit, i know that the exedy clutch fits for 91-00 d-series trannies. (ref: http://www.superhonda.com/foru....html)
