2 Stanton STR8-80's w/new needles!! Only $200!
Old Mar 20, 2007 | 11:28 AM
DJEvo1200's Avatar
Default 2 Stanton STR8-80's w/new needles!! Only $200!
That's right, I have run out of time to spin at home, and need to fund new projects. I am letting these babies go for a song, only $200 for the pair! I recently installed new styli on the stock headshells, Stanton 510SK's. They are in great condition, some minor scratches and the like, and even includes covers and slipmats! Here are some specs and pics below:
Features
Reverse and motor off functions
3.5mm line input built-in (for portable CDs, MDs, or any other line source) cable incluced
Key adjustment (A.K.A. master tempo)
Quartz lock (A.K.A. Pitch On/Off)
3 speeds: 33, 45, 78 rpm
Selectable pitch adjustment (+/-8%, 12%)
Skip-proof straight tone arm!
Blue LEDs
Remote Start
Adjustable feet
Includes dust cover and slipmat
SP/DIF digital output
Direct drive motor
Aluminum platter
Target light
Blue strobe indicator
Technical Info
Motor: 8 Pole, 3 Phase, Brushless DC motor
Turntable Platter: 330mm dia. Aluminum diecast
Wow and Flutter: Less than 0.20% WRMS (JIS WTD) with 33 1/3 RPM
S/N Ratio: More than 50dB (DIN-B)
Pitch Controls: +/-12%, +/-8%
Starting Torque: More than 1.6 kgf.cm
Braking System: Electronic Brake
Channel Separation: 16dB
Dimensions (W x H x D): 17-3/4 x 5 x 13-3/4 in.
Weight: 19 lbs
Old Mar 20, 2007 | 05:14 PM
DJEvo1200's Avatar
Default Re: 2 Stanton STR8-80's w/new needles!! Only $200! (DJEvo1200)
Evening bump!
Old Mar 21, 2007 | 11:30 AM
DJEvo1200's Avatar
TTT
Old Mar 21, 2007 | 08:30 PM
Mr.OB*GYN_Rhett's Avatar
had the str8 90s, good ish
Old Mar 22, 2007 | 04:36 AM
perseverance's Avatar
deal
Old Mar 22, 2007 | 04:42 AM
DJEvo1200's Avatar
SOLD!!!!
havokgroup.com
Apr 24, 2007 07:25 PM
em Dot
Jun 9, 2004 09:51 AM
Jesse H
Aug 7, 2002 05:44 AM
