CTR side moldings
to get the OEM off you have to pop off the clips on the inside of the body of the car. Front fenders are easy you can take off the inner fender and gain access or take the fender off all together,only on the fenders is there also a small strip of adhesive. The doors you need to removed the door panels and the plastic cover and you'll see them, there's also a plastic nut along with the clips located at the furthest back part on the door. The rear section is the worst because you have to pretty much gut the interior to access the clips.
the easiest way is, and if you dont care about your old moldings, is to to just use a flat head screwdriver wrapped with a thin layer of cloth and pop them out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GG99 »</TD></TR><TR><TD CLASS="quote">the easiest way is, and if you dont care about your old moldings, is to to just use a flat head screwdriver wrapped with a thin layer of cloth and pop them out.</TD></TR></TABLE>
this is the easy way. otherwise, u gotta take off your fender to pop that one off and then for the rest you gotta get the panels off.
FRKWOO
Dec 26, 2008 12:28 AM
