turbo question
Old Mar 19, 2007 | 09:18 PM
drew338's Avatar
Default turbo question
I was woundering if its posible to turbo my 2000 SH with 100K on it with low boost. just want to know if its posible? or should i just rebuild then turbo?
Old Mar 19, 2007 | 09:23 PM
Hawkze_2.3's Avatar
Default Re: turbo question (drew338)
Read the Prelude turbo thread, it's not that simple.
Old Mar 19, 2007 | 09:27 PM
drew338's Avatar
Default Re: turbo question (Hawkze_2.3)
forgot about that sorry. but im just woundering if my motor can handle it?
Old Mar 19, 2007 | 09:29 PM
thegeorge613's Avatar
I suggest rebuilding, then turbo just to be on the safe side. If you could afford it, sleeve your block and run forged pistons so you can handle more boost.
Old Mar 19, 2007 | 09:32 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drew338 &raquo;</TD></TR><TR><TD CLASS="quote">forgot about that sorry. but im just woundering if my motor can handle it?</TD></TR></TABLE>
Maybe? If you have a good tune....why would 100K make it not able handle boost compared to a new engine? Your ATTS is a major crutch anyway.
Old Mar 19, 2007 | 09:36 PM
drew338's Avatar
What can i do about that? Ive heard it wouldnt work over HP but hows that?
Old Mar 19, 2007 | 09:47 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drew338 &raquo;</TD></TR><TR><TD CLASS="quote">What can i do about that? Ive heard it wouldnt work over HP but hows that?</TD></TR></TABLE>
You can swap in a non-ATTS H22. As I understand it the little clutches inside can't handle more than 250hp or so...somebody correct me if I'm wrong....
Old Mar 19, 2007 | 10:03 PM
vinuneuro's Avatar
Do compression and leakdown tests first.
Old Mar 20, 2007 | 11:19 AM
drew338's Avatar
so its not worth turboing an sh then. would it be better to go N/A with an sh?
Old Mar 20, 2007 | 12:50 PM
Chuckles99SH's Avatar
Default Re: (drew338)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drew338 &raquo;</TD></TR><TR><TD CLASS="quote">so its not worth turboing an sh then. would it be better to go N/A with an sh?</TD></TR></TABLE>
It would be better to read up on the FAQ. Nuff said.
Old Mar 20, 2007 | 01:01 PM
TDCTyler's Avatar
Just make sure you have a healthy motor, then go for it. I have had my SH boosted for 2 years 10-psi 8k rpm everyday with no issues. you have to disconect the atts computer anyways when you use engine management so its pretty much just sitting there and doesnt do anything.
em1gangsta
15
Feb 3, 2008 11:26 AM
beaversdc5
14
Oct 29, 2007 05:29 PM
projectef
Jul 3, 2007 08:35 PM
akoreanyoungsta
21
Jun 10, 2006 11:18 AM
PnoyJeff
Jan 26, 2005 03:22 PM
