Help Integra type r headlight wiring (searched)
Old Mar 19, 2007 | 08:34 PM
kauaiboy66's Avatar
Default Help Integra type r headlight wiring (searched)
I need help wiring the highlights on the type r headlights do I need a relay or something???? please help me out
I know that you use the stock ground from the highlights but when I put the other wire on it does not turn on......
I know that someone out there has an anwser....
Thanks in advance
Modified by kauaiboy66 at 10:23 PM 3/19/2007
Old Mar 19, 2007 | 10:30 PM
thaiphob's Avatar
Nikon!!!
Default Re: Help Integra type r headlight wiring (kauaiboy66)
Just look behind the brown plug for these colors and attach Via Female Insulated Spade terminal
Harness Wiring ------------------------------ Car Wiring
White ------------------------------ Low Beam (+)
<FONT COLOR="red">Red</FONT> ------------------------------ High Beam (+)
Black ------------------------------ Headlight Ground (-) {Connect the 2 Ground wires - 1 went to the High Beam plug and 1 went to the Low beam plug}
<FONT COLOR="blue">Blue</FONT> ------------------------------ Fog Light (+) {Connect using OEM Fog Light wiring, If you do not have it Contact a shop for a how to on wiring or Search HT}
<FONT COLOR="green">Green</FONT> ------------------------------ Parking/City Light (+) {Connect to the Parking (+) wire that is connected to the USDM Turn signal socket that Was in the Bumper Lense on the US Front. (Has 3 wires - 1 is a Ground (-), 1 is a (+) for Turn Signal, and 1 is a (+) for parking Light.}
{It should be a Red wire with Black Stripe, test First with Volt meter}
Old Mar 19, 2007 | 10:41 PM
kauaiboy66's Avatar
Default Re: Help Integra type r headlight wiring (thaiphob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thaiphob &raquo;</TD></TR><TR><TD CLASS="quote">Just look behind the brown plug for these colors and attach Via Female Insulated Spade terminal
{It should be a Red wire with Black Stripe, test First with Volt meter}</TD></TR></TABLE>
So I need 2 ground wires one from the stock high beam and the low beam one???
thanks for your reply
Old Mar 19, 2007 | 11:49 PM
pdotjones's Avatar
i got this from this topic https://honda-tech.com/zerothread?id=1638414
Old Mar 28, 2007 | 10:31 PM
kmos's Avatar
on the turn signals. it looks like the green one is usually off and only comes on to blink. while the brown one is constantly on since it's being used for city lights.
can someone confirm this?
303_Rogue
Jul 1, 2016 05:34 PM
buymesomedunks
Feb 22, 2010 06:33 PM
JDMDC2BOY12
Aug 9, 2008 07:17 AM
ST
May 26, 2005 09:28 PM
canuck-mx6
Feb 21, 2003 11:36 AM
